hi all...
snapped a little green plasic plug of my block when i pulled it out..
hoping someone with fast knowledge can help me out here for a part number
it has a plug connected to it, theres 2 (one is fine and sits slightly ferther along the block)....and i believe there coolant related...
https://www.sau.com.au/forums/topic/337405-whats-this-part/
hi all...
KNock sensors
https://www.sau.com.au/forums/topic/337405-whats-this-part/#findComment-5454601
I pulled my engine out the other day and seen these plugs. Even if its broken on the end you should be able to still put the wire on it. The green part is just there to hold the plug. You could super glue the end back on. There should be a pin still in the middle of it you can attach the wire back on to
https://www.sau.com.au/forums/topic/337405-whats-this-part/#findComment-5454605
yeh it kinda tore the thing out... i could get a ghetto set up happening i spose... but is it the thing i want to half job...??
is there 1 for 3 cyl?
a new one going to cost me an arm and a leg isnt it lol:(
https://www.sau.com.au/forums/topic/337405-whats-this-part/#findComment-5454630
Just get one from a wreckers. they are a bitch to get at with engine in, and if the connections fails it will log fault codes AND run off the knock maps (both fuel and timing).
https://www.sau.com.au/forums/topic/337405-whats-this-part/#findComment-5454641
yeah ok... do both while im there or just 1?
does anyone have a part number
it doesnt say 34.. but do we think this would work?http://cgi.ebay.com.au/Skyline-GTS-T-R32-R33-RB25-RB20-Knock-Sensor-DET-Sensor-/180553906563?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a09d9f983
Edited by chef_stagea
https://www.sau.com.au/forums/topic/337405-whats-this-part/#findComment-5454646
Its the same one for all rb20, and rb 25's. Seems rb26's are different
Send me your vin no and ill get the correct number
Edited by kjb_r33
https://www.sau.com.au/forums/topic/337405-whats-this-part/#findComment-5454674
Thanx mike ill hit up jis tomoz and c what there plans are vs nissan! Part number would be great
22060-56S10
I supplied the RB26 part number as it states in his user details that its a 260rs
Car(s): s1 260rs stagea
Edited by kjb_r33
https://www.sau.com.au/forums/topic/337405-whats-this-part/#findComment-5454857
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
