Hi,
Items are located in Sydney's West.
NEW R32/33/34 GTR upper radiator bushes set of 2 bushes $20 delivered
NEW OEM Top Injector o-ring set of 6 $50 delivered
NEW Yokohama A-Drives set of 4, 265/35/R18 $1200 for the set.
NEW The SARD M.F.C. (Multiple Fan Controller) $170. Got a haltech so no need for this anymore.
Never used or installed HALTECH IQ3 Display Dash - Reads Vnet Sensors and includes Internal CAN Interface Module to read Haltech ECU info/sensors $900
LS1 coils, leads and brackets (mounts above injector rail) $700.
R33 GTR front Guards and raisers. $550 in silver.
R33 Series 3 Xenons, near new. not seen any road kms..
Cheers,
Johno
$2400 for the lights, they are near new. only fitted to the car and litterally run on the dyno and towed home. The lights were purchased from RHD Japan. They are now on there for a whooping $4105 delivered to OZ!
http://www.rhdjapan.com/bcnr33-kouki-xenon...eadlights-12139
I have a bad habit of buying parts then falling short of $$ for the home loan lol.
Cheers,
Johno
do the guards come with the side skirt addons and can I see the pics of them?
If so price to Mansfield, QLD 4122
Pics of guards attached raiser are not in the pic but are included. Side skirt add on is not included.
Pics of Yoko's too
pics of coils plz
This is the only pic I have of the coils at the moment, I'll dummy fit it over the weekend to show how it all fits and looks. It is similar to the 101 imports gtr set up but not as neat.
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
