6bolt drive shafts $100
s14 nismo 2way lsd centre,with 6 bolt half shafts $400
5 bolt drive shafts $80
r32 gtst rear 5stud hubs,brakes,hand brake set up $250
r32 rear cradle with all arms $100
r32 lsd diff $100
r32 clutch pedal, clutch master cylinder,slave cylinder,and all the lines between $200
r32 manual brake pedal $40
r32 brake booster and master cylinder$80
r32 excelerator pedal and cable $40
r32 charcol canister$20
rb20 top timeing belt cover $10
r32 hand brake $40
r32 heater core and evaporator assbly $100
brand new walker rear cannon 2ich inlet 4ich out let $50
brand new walker cat 2ich in 2ich out $50
brand new walker middle muffler 2inch in 2ich out $50
rb25 cam covers$40
rb25 coilpack cover$10
rb25 top timeing belt cover$10
r32 climate control unit$50
r32 drivers side window switch assmbly $50
rb25 crank angle sensor$50
rb25 intake manifold,bare top and bottom half$40
pioneer mini disc player$40
rb20 engine,coilpack,loom$150
r32 steering colum with ignition barrel and key$50
r32 fiber glass rear pods,small crak in one$40
rb20 hicus power steering pump $40
rb20 afm green label $50
r32 front wiper arms$15 for the pair
r32 front rotors $30pair
rb20 egine mounts$30pair
rb20 coil pack brakets$20
rb20 back plate,that goes between box and motor$10
rb20 red top cam covers and top timeing belt cover painted red with the lines sanded back$60
located strathalbyn SA 0431 540 141
can post some of the small items
hey mate, might be interested in the r32 gtst rear 5stud hubs,brakes,hand brake set up and possibly the charcol canister aswell. Im in Rostrevor, Strathalbyn is a little far, do you ever come abit closer?
yeah dude come to town a fair bit.i can meat you at mt barker or something or when i come to town next ill bring them
Hi mate im interested in the brake master n booster, is it in good working order ie no leaks? can u post to nsw 2464?
hey dude yeh its in good order,postage is $30buks,let me no if you are wanting it still
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
