6bolt drive shafts $100
s14 nismo 2way lsd centre,with 6 bolt half shafts $400
5 bolt drive shafts $80
r32 gtst rear 5stud hubs,brakes,hand brake set up $250
r32 rear cradle with all arms $100
r32 lsd diff $100
r32 clutch pedal, clutch master cylinder,slave cylinder,and all the lines between $200
r32 manual brake pedal $40
r32 brake booster and master cylinder$80
r32 excelerator pedal and cable $40
r32 charcol canister$20
rb20 top timeing belt cover $10
r32 hand brake $40
r32 heater core and evaporator assbly $100
brand new walker rear cannon 2ich inlet 4ich out let $50
brand new walker cat 2ich in 2ich out $50
brand new walker middle muffler 2inch in 2ich out $50
rb25 cam covers$40
rb25 coilpack cover$10
rb25 top timeing belt cover$10
r32 climate control unit$50
r32 drivers side window switch assmbly $50
rb25 crank angle sensor$50
rb25 intake manifold,bare top and bottom half$40
pioneer mini disc player$40
rb20 engine,coilpack,loom$150
r32 steering colum with ignition barrel and key$50
r32 fiber glass rear pods,small crak in one$40
rb20 hicus power steering pump $40
rb20 afm green label $50
r32 front wiper arms$15 for the pair
r32 front rotors $30pair
rb20 egine mounts$30pair
rb20 coil pack brakets$20
rb20 back plate,that goes between box and motor$10
rb20 red top cam covers and top timeing belt cover painted red with the lines sanded back$60
located strathalbyn SA 0431 540 141
can post some of the small items
hey mate, might be interested in the r32 gtst rear 5stud hubs,brakes,hand brake set up and possibly the charcol canister aswell. Im in Rostrevor, Strathalbyn is a little far, do you ever come abit closer?
yeah dude come to town a fair bit.i can meat you at mt barker or something or when i come to town next ill bring them
Hi mate im interested in the brake master n booster, is it in good working order ie no leaks? can u post to nsw 2464?
hey dude yeh its in good order,postage is $30buks,let me no if you are wanting it still
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
