Hi there, have the following parts for sale. Am located in Brisbane, so to all those interested in Brisbane, give me a PM or call me on 0421139371.
Thanks
Garrett GT3076R .63 Rear Housing - $1100
Apexi EL2 Mechanical Boost Gauge White Face/Blue Illumination - $180
GReddy Type RS BOV - $120
Front Mount Intercooler 550x200x88 2.5" Inlet/Outlet - $180
Walbro Fuel Pump 255LPH - $120
Drift Stainless Steel Air Filter - $70
MWR 630cc Injectors (Suit 1ZZ-2ZZ & More) - $280
Apexi Power FC With Hand Controller (Toyota Celica 2ZZ-GE) - $890
still got the turbo for sale?? how much work has it done and what sort of power was it making??
Hi there, turbo is still for sale. Was used for about 25k km's or less and made 280kw atw, running 0.7 bar of boost.
Thanks
Thanks
Any shaft play? Was it ever serviced? What oil did you run in your engine/turbo?
Thanks
Thanks
No shaft play at all. Has never been serviced. Used Nulon fully synthetic 5W-30.
Thanks
will fuel pump fit r33 gtst?
and run well enough to make 250kw?
cheers
chris
Hi there, yes fuel pump will fit R33 and will handle 250kw no problems
Thanks
Price is firm on BOV to all those interested. If you search around, a genuine GReddy Type RS BOV goes for more than what's asked.
Thanks
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
