hey, just wondering what kind of fuel cut off the NEO enigne uses? does it stop the fuel pump or does it stop the injectors when overboosting or the so called "fuel cut"
if im using the 2 stage solenoid, my engine goes alright till about 4,5k rpm, after that the full boost kicks in and it just makes loud popping noises, and stops accelerating. now if i bypass the 2 stage solenoid by just removing it and connecting the pipes together, full boost kicks in at about 3k rpm and the loud popping noise kicks in there.
but as soon as i get to about 5,5-6k rpm i get full boost again and the car just flies till it hits the limiter.
now i havent had time to do the trick with grounding the fuel pump continually to supply the full 12v, but apparently that fixes it.
so just wondering if the fuel pump stops pumping, the injectors stop or if, like the supra, it stops the spark plugs from firing.
what would get around this? im looking at either getting a nistune or buying a power fc.
guessing the power fc will remove of it, but will the nistune?
cheers
Jean
https://www.sau.com.au/forums/topic/337491-rb25det-cut-off/
so you are only running stock boost levels? what other mods do you have?
if it is stock boost and the rest of the car is pretty stock then it doesn't sound like you are hitting any sort of boost cut (as it generally doesn't result in a missfire in the skylines). it sounds more like either your coils are stuffed, or your spark plugs are, or both.
how old are the spark plugs, and do you know what type, gap and heat range they are?
https://www.sau.com.au/forums/topic/337491-rb25det-cut-off/#findComment-5455975
whole car is stock, everything is brand new dont know the exact gap, i think it was .8mm not too sure, only other thing i have is a 3" dump and catback system.
its the engine in the s2 stagea, but same ecu etc.
actually the above is true, but only at certain times, i can go past those revs perfectly if i only use 3/4 throttle, this only happens when its hot and i use full throttle, if air outside is below 20dC and i use full throttle, it kicks in a bit later, around 5k-6k rpm.
but i dont know why it dont happen after 6krpm? after that i can kick it as hard as i want, no misfiring nothing.
https://www.sau.com.au/forums/topic/337491-rb25det-cut-off/#findComment-5455988
oh yes, and also to mention, this may be really weird, but at full throttle i can rev all the way through if im not in gear but in neutral. so just parked, and gearstick isnt in gear, i can put foot to floor and no stuttering, just perfect revs and boost. kinda weird??? some other cars i know have had that too
https://www.sau.com.au/forums/topic/337491-rb25det-cut-off/#findComment-5456859
fixed the problem, the dealer said they changed the sparkies, but they didnt, they are burned through to the sh*thouse, so changed them with some NGK's and daaaaaaaaamn, car is very very fast now.
but coils are still newish, so drew the lucky straw
https://www.sau.com.au/forums/topic/337491-rb25det-cut-off/#findComment-5460724
nah, they didnt change the plugs, they had holes fired into the bottom. they were really used out. luckily it all got fixed, i got some iridium IX and i was done with it. if i could have had extra time i would have loved to check out pulseplugs though. 130 bucks for all 6. wonder how they would go
https://www.sau.com.au/forums/topic/337491-rb25det-cut-off/#findComment-5461508
There are horrific stories on here of people using a plug that was too hot and it looks burnt out and destroyed after a few hundred km. One guy melted his after one flat out tin to 180km/h.
A lot of sau users use coppers because
1 They're cheap
2 Changing every 5000km means that they're constantly fresh and being inspected
3 There are HEAPS of stories of iridiums lasting only 3000km
4 Copper has a slightly better spark but also wears more quickly (hence the high change rates)
I use bosch plats myself and change every ~5000km, or a bit after. 6 for $38 for 1.1 gapped, and $44 for 0.8 gapped.
https://www.sau.com.au/forums/topic/337491-rb25det-cut-off/#findComment-5461548
well, for the iridium, i didnt actually pay anything, the mechanic that had them is a really good friend of mine so he gave them to me. but daaaaaamn, gotta drive carefully.
so i guess after about 5000km ill change to pulseplugs to see what they are like.
https://www.sau.com.au/forums/topic/337491-rb25det-cut-off/#findComment-5461681
Sorry mate, I just re-read my post, should have mentioned there are also plenty of people who get 40000-100000km out of iridiums. Luck of the draw really. A mate of mine spent weeks hunting a misfire on his soarer, spending hundreds replacing parts, including coilpacks, and it turned out to be the 3000km old iridiums. He was not impressed lol.
But anyways, you'll know as soon as the plugs start going off mate, it'll mis a bit at idle and high boost.
I'd keep the iridiums until they had a problem, you might be lucky >_<
https://www.sau.com.au/forums/topic/337491-rb25det-cut-off/#findComment-5461695
hEY BRONX,
I have a similar prob on my 34GTT, I have 3inch full turbo back zorst, pod filter in custom cold air box, boost set to 12psi with manual boost controller, short shift kit and thats it. Dunno if my ECU has been programmed to handle this boost by previous owner. Anyways my issue:
My car revs sweetly all the way to 4800ish rpm ( full boost of 12psi kicks in at around 2500-3000rpm). Then from 4.8k to around 5200-5400rpm I get that sort of popping sound u talking of and no acceleration, like the car has suddenly become NA, dunno what boost it is on at this point, but theres just no feeling of boost/turbo at this band. Then from 5400 to 6800rpm the car REALLY flies - constant 12psi and smooth revving all the way ( it still never hits the 7000rpm redline but cuts off around 6800rpm???) Why dont I k\hit 7rpm?
It really bugs me as to why it ( the flat spot / NA feeling and popping ) happens on this 4.8-5.4k rpm band ONLY, do you guys recommend I do the plugs - NGK Iridiums?? I'm sure its not the coil packs.
I'm gona do a proper FMIC and NIstune next year though.
cheers RON :banana:
https://www.sau.com.au/forums/topic/337491-rb25det-cut-off/#findComment-5476546
like advised before, check your sparks, thats my best guess even if your car seems to go a bit past the 12psi, i think facotry max was 15psi? it can still get blowout. found the best gap for that amount of psi is .8mm.
check it out and post back, or if your sparks are fine and set correctly, it could be your fuel pump not being able to deliver at that high boost and rpm.
if you need any help, im in sydney so i can help you with anything you need
cheers
Jean
https://www.sau.com.au/forums/topic/337491-rb25det-cut-off/#findComment-5477111
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
