Well ive got the best for sale and cheap. Perfect for a GTST or GTR.
GTR 180KM/H Cluster with 18000KM
GTR Centre Gauges - (SOLD)
$240 for Cluster + postage
Prefer melbourne buyers but willing to ship interstate at buyers expense.
PM me if interested
https://www.sau.com.au/forums/topic/33753-gtr-cluster-centre-gauges-cheap/
Guest RedLineGTR
You can only get two out of the three gauges too work on a gtst with a gtr they have thier own lume to connect too it. You also need a stock gtr aircon unit (Panel) if you want them both to fit like on a gtr unless u want to muck around with brackets and bodgy jobs. There have been a couple of threads about this check the search if you have time.
redline,
do you mean that i cant use back my std GTST climate control ?
what if i put that underneath the triple gauge thingy ?]
i know that there would be a small gap in between the climate control and
the triple gauge thingy but i can live with that .. :Oops:
  • 2 months later...
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
