1996 R33 Gtst, Series 2, Manual, White
This is a very regretful sale! Reason for selling is I now only require one car and there is no need for the second. Make my loss your gain biggrin.gif
-RB25DET
-Manual
-Electric Sunroof
-Climate Control
-Dual Airbags
-89,000 Km's
Modifications Include:
  • Full 400R kit
  • 17" mesh/dished rims
  • Tinted Windows
  • Bolt in Half Cage, very neat installation.
  • Nismo Dash (white, 320km/h speedo)
  • Bilstein Coil over suspension
  • Nismo wishbones
  • Ganador Aero Mirrors (electric)
  • Nismo clear side indicators
  • Apexi PowerFC & Commander (Hand-Controller)
  • Stainless split dump/front pipe.
  • 3" Fujistubo Cat-Back exhaust; fairly quiet.
  • Drift Pod Filter
  • Greddy FMIC
  • Tomei Fuel Pump
  • Exedy Sports Organic Clutch – Rated to 270rwkw
  • Bendix Street Road Track brake pads
  • Greddy Profec B Spec II Boost Controller
  • Iridium Spark Plugs
  • Full Mongoose alarm, immobiliser and central locking
  • New 610 CCA Battery
  • JVC Mp3 Player,Front Aux In, Sub Out
  • Alpine 6.5" Coax Front
  • New Rear Tires
  • 12" alpine type S sub in box with alpine mono D amp
Car is currently producing 220rwkw and was tuned by Boost Automotive. Low boost is set to 11psi and high boost is set to 14psi on BP ultimate.
This car drives great and handles very well. Mechanically the car is 100% and the interior is in very good condition/very clean.
The only issue with this car is a few cracks/chips on the front bar/body kit from driveways and could do with a replacement.
Car is registered in Tasmania but is currently located in the ACT.
This car has been treated and looked after very well and always garaged.
Serviced every 5000K's since owned with Castrol Edge fully synthetic oil.
Anything else please don't hesitate to PM / call or msg 0439072190.
$12,000 ONO
All Offers Welcome :)
Car is also on Car Sales with the following link : http://www.carsales.com.au/used-cars/priva...0&D=9253340
Please see pics below:
Edited by Spraderz-33
https://www.sau.com.au/forums/topic/337533-96-r33-gtst-sii-manual-white/
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
