Hey guys
ive got an r33 rb25det, 3076R
ive just thrown on my plasmaman and am looking at upgrading to a 6 boost manifold.
i'm upgrading my rear housing on my 3076 to .84
and have the option of going external or internal gate
the best option seems to be external gate with the 6 boost, with a decent wastegate.
i'd prefer to keep internal gate. if i can get a similar result. without many hassles
does anyone know anybody that has done this already? am i wasting my time?
looking to hit high 200's with this setup.
https://www.sau.com.au/forums/topic/337540-6boost-with-internal-gate-3076r/
You seem to have answered your own question. From a technical perspective, a manifold that allows more efficient flow and cylinder scavenging is the thing to have.
Also an external gate properly set up will offer better venting and boost control.
There was a comment from Al who wants to go to virtually the type of turbo system you ask about, from an IW, collector style manifold on the basis of boost control and efficiency. That would/could open up the option of using split pulse too.
But there are many people easily achieving 400 rwhp +/- 15 using OEM manifold and IW turbine. A very tidy result at significantly less outlay. And it works superbly on a street car. If you were keen and capable, it is possible to smooth some internal sharp edges/restrictions in the OEM manifold too. Unknown exactly how much advantage this gives, but every little bit would help.
If you were chasing higher hp and using a GT35 turbo, then I'd have no hesitation in going 6boost + EW.
For me it's a question of performance target and budget.
I think provided you supported the turbocharger/dump pipe/exhaust system with factory style bracing a cleaned up std exhaust manifold would work fine . You have one already and it will look more factory obviously because it is , if you can use some of the std heat shielding more of the above .
Exotic manifolds are nice but the exercise can be involved and expensive for a road car , plenty of people here have simply bolted those turbos with a spacer on the std manifold and got more than adequate squirt from the retuned engine .
Real good bang for buck and if for any reason you had to return the car to std its a lot less work to do so .
A .
thanx for the feedback guys.
The main factor that i am interested in going to a 6 boost style manifold is that i love the look of the turbo sitting up high.
plus its only $500 for the manifold, aswell as my own time in fitment and fabrication.
i know i can get the same result from the standard exhaust manifold and keep internal gate,
i honestly didn't think that i am forced to go "external gate" just to use a 6 boost.
You probably wont be for long when he finds out you are telling people you got it that cheap.
I also recall they can be made with no gate extension.
who ever said that i would be getting one new off 6 boost.?
buying one that was bought for a project but never used.
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
