Hey everyone,
I'm new on here (and reasonably new to the world of Skyline ownership!) and wish my first post was slightly more positive but...
I was just woken up to the sound of my car being broken into, and am now left with glass everywhere and one window short :down: I guess that on the bright side my alarm scared them off before they could grab anything...
Anyway, I have had a quick search around to no avail and was wondering if anyone could had any thoughts on rough costs/recommendations for a place to get it repaired? I've never been in this situation before :S
Thanks
https://www.sau.com.au/forums/topic/337570-best-window-glazier-in-canberra/
Oh crap.... sorry to hear that :down: Stupid thieves :(
I'm sure most glass replacement places would do it? Or you could source one from a wrecker/import workshop, or on here, and then just pay for the labour?
Or if you're with Shannons or another insurer who has free glass replacement you could probably get it fixed for nothing.
thanks heaps! ill give them a call tomorrow morning and see whos cheapest :down:
im a little worried now cos i don't know where to park my car in case they come back.. i think i'm gonna invest in one of those covers and hope for the best. the car needs a pin code to start so hopefully that will scare them off!
I'd just make sure there's nothing in it to steal and tape up the window with some plastic or something for tonight... Obriens or similar should be able to do it for you tomorrow if you ring up early :down:
i assume its the door glass?
they're usually pretty expensive just for the glass. I sourced one for my car (its not a skyline) in Sydney and picked it up after a ACT panel shop smashed mine. even second hand it was close to that.
Wrecker in queanbeyan had an r33 with both doors and windows a lil while back.
BTW - Obrien's did a chip repair for me today and it was $150 for a chip on the front windscreen passenger side.
Thinking I should have had the the windscreen replaced for $300 at that price.
Especially as it left a mark even after the repair.
I had no idea it was so expensive! :O Makes a lot of sense to go with an insurer who has the "1 free window replacement per year" type thing, $500-$700 is a large chunk of your premium essentially paid for!
yeah its not the door window but the one behind it. queanbeyan have one but havent gotten back to me yet to pick it up, so still waiting.
f**k i wish i left the car open and they just took the cd player, nothing else of value in there.
depressing :laugh:
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
