For sale is a bt1 vl sl
Original white
Original a8 block
T3/t4 high flowed turbo
Microtech plug and play lt10s with hand controller
3200 rpm stally manulised jatco box
Included in sale is B&M pro ratchet shifter in box new
Auto meter guages
Lowered
Tinted windows
$7836 of recepits just for the head work
On interceptors
Big front mount tucked behind bar sleeper look
Dyno sheets for 166.1kw & 920 nm
More things just can't think atm
Bad points
No rego
3x small rust spots
unis need doing have them just haven't got round too doing it
Car is at harrington nsw. I live in newcastle so have too arrange time too have a look
Contact jahn on 0432163488
$8000 maybe swaps really want cash heaps more just I'm not near the car so can't remeber everything
Pics up soon as possible
https://www.sau.com.au/forums/topic/337593-vl-bt1-turbo/
post-75643-1285375337_thumb.jpgpost-75643-1285375289_thumb.jpgpost-75643-1285375261_thumb.jpgpost-75643-1285375236_thumb.jpgpost-75643-1285375201_thumb.jpgpost-75643-1285375201_thumb.jpgpost-75643-1285375156_thumb.jpgpost-75643-1285375114_thumb.jpgpost-75643-1285375114_thumb.jpg
Original white
Original a8 block
Auto meter guages
Lowered
Tinted windows
On interceptors
Bad points
No rego
3x small rust spots
https://www.sau.com.au/forums/topic/337593-vl-bt1-turbo/#findComment-5464951
how many k's on it mate?
Not exactly sure but the motor and driveline are all rebuilt supposed forged bottom end and fully built head have recipts for all work
https://www.sau.com.au/forums/topic/337593-vl-bt1-turbo/#findComment-5481188
$7500 mods done too this are worth way more just needs wastegate actuator mod then bump the boost up genuine bt1 all matching numbers supposed forged bottom end no recepits but
https://www.sau.com.au/forums/topic/337593-vl-bt1-turbo/#findComment-5497775
  • 1 month later...
  • 3 weeks later...
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
