Hey everyone,
um a couple of weeks back sometimes my car didnt start, then i would try again and it would kick over. As time passed it got worse until last friday afternoon where the car would not start at all. I do have an imobilizer and when i unlock it and turn the ignition switch over i get all the lights on the dash (normal pre start lights) and hear my fuel pump prime. However it just dosnt seem to kick over. I even tried to jump start it with jumper leeds thinking it was a flat battery however that didn't solve the problem. In the end a few of my mates and i ended up pushing starting the car which seems to work fine without any hesitation.
My first thought was it must be the starter motor, so i brought one of them from a guy on the forums. Today i swapped it over thinking i could drive my car again and went to turn the key and again no luck, the car didn't start..
So my question is, does anybody know whats wrong with my car? or what i could check to see if that's the issue?
cheers guys, Niran
https://www.sau.com.au/forums/topic/337644-car-not-starting/
do the headlights dim when u try to crank it over?
hey man, um nah headlights and all stay the same brightness when i try to crank it over. nothing happens the warning light for i think cat comes on? the one that looks like a catalytic cover-tor sign and has waves off it.. representing heat im assuming..
when you try to start it, does it turn over or just make a clicking noise?
hey, nah dosnt turn over at all just makes a clicking noise from the inside of the car which is coming from the fuse box under the steering wheel
thats flat battery... either get a jump pack or a new battery... it will start
Jarrod
hey man,
thanks dude, i put mums cars battery in mine and it started :S .. no idea why it didnt start before when i tried to jump start it with jumper leeds.
thanks again
no worries, jumper leads dont deliver enough current to get the car started when the battery is fairly flat, could be due to the cheap leads i have but ive always had to leave them on for a good 15 mins with the other car running to get it started... a jumper pack however fires it up first go every time :)
Jarrod
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
