My engine builder was finishing off my 26/30 today when one of the tomei camsahfts snapped.
Has this has happened to anyone else???
I am certain this is not an insullation fault or damage due to transit as the boxes were in mint condition and there is not a mark on the camshaft.
The intake cam will be crack tested tomorrow.
Have a look at the photos, please - let me know yr thoughts. Note no oil was added to the break. The clean/fresh bit of metal in the centre was how it looked when it broke.
https://www.sau.com.au/forums/topic/337672-tomei-camshaft-failure/
If you say thats exactly how it looked when it snapped then it's definatley a problem with the casting. I don't know what tomei's quality control in reguards to crack testing is but this one slipped through. The dull outer area would be coolant that seeped into the crack during grinding. You can snap a perfectly good cast cam from improper installation or removal but any micro cracks in the castin will make it snap a lot easier.
happened to one of my friend's car. Engine's freshly built. Mechanic found one cam gear was very spinable while installing timing belt. Brand new cam shaft in half on engine stand. I would say its manufacturing related. Email Tomei and ask them for exchange.
instilation error is the only way.
from the look of it, where it has broken is the loaded lobe when instaling. ie cam clocked in the timing of #1 tdc.. they can get caught on the front thrust bearing/cap if not done very carefully.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
