start /rant
Was wondering if anybody feels discriminated against just cause your Skyline is NA. I kinda feel it a bit.
Haven't been on a dyno day yet, still waiting till it's $40-$50 again. But it's gonna be pretty awkward cause all the fully sickers are gonna expect 99999kW just cause it's a Skyline just to be heart broken cause it's NA. Also the community and it shows on this forum too; it's like if your Skyline isn't turboed it isn't considered a Skyline or something, people don't wanna help you as much, all the comments revolve around 'get a turbo' etc. Maybe i'm just biatching but you know it's true lol.
end /rant
https://www.sau.com.au/forums/topic/337691-anyone-feel-left-out/
  • Replies 44
well im from canada and i understand you guys in aus have stricter driving/vehicle compliance rules down there so my comment may not really apply but up here if your going to get a skyline there is absolutly no reason to get a n/a one seeing as how the price difference for importing one is almost non existant. there is no reason or us to import a n/a because you no longer have the perormance factor. might as well buy a comparable gutless 2L domestic vehicle which has the steeringwheel on the proper side for our roads (we drive left hand drive) for less money and substancially cheaper/more available parts. up here if you have n/a you get looked down upon because it just doesnt make sense. i understand my comment may not apply because of p platers i believe there called(learners licence holders???) who cannot drive modiied/turbo'd cars?
Because its true - best bang for your buck modification for an N/A Skyline is to go down the turbo route... anything else while keeping it N/A is going to cost you lots of money for very little gain.
Unless your restricted by P plate laws in which case I dont think your allowed to modify the engine at all anyways regardless if its N/A.
if your Skyline isn't turboed it isn't considered a REAL Skyline
fixed :)
You can be an enthusiast and own a gogomobile
You can be an enthusiast and own a 911 turbo
The losers are the ones who...
i) are condescending at others and their cars
ii) don't know how to treat a car (-yes even if it's a 911)
iii) spend $$$ on grog/drugs instead of upgrading their car
iv) are jealous and discriminate half-cocked
v) try and pretend to be something they're not
An enthusiast can be proud of his/her car!
I'd rather have a NA skyline than any sort of commonwhore, except maybe a VL which at least had the right engine in it (but it's turbo so not an option for P platers).
Dunno what you're whining about though. My first car was a Charade, and you think an NA skyline is a sorry option? You should harden up a bit, princess.
^^^ agreed
my next car will be an NA
we dont have P plates over here (new zealand) so turbos are no restriction (yet) so every second person has or had one
hardly see any NA tuned cars
Edited by C33Burgerman
Hey mate, everyone has to start somewhere.
I started out in a Gemini then went to a Niki 650.
Now i have a boonger R31 and a C33 Laurel. My missus has a Stagea.
Point is, you gotta work up in the cars, no point (in my case) owning a Niki 650 then jumping into a R33 and almost killing yourself with the added 250kw extra power than the 3kw Niki.
If i could get myself a N/A R32 and sell my R31 i would in a heart beat!
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
