and when you drive a 32R, people will ask, why not 33R or 34R
Because the GTR 32 are the lightest Sleakest GTR, 33s are not as pretty and the 34 is very chunky looking not my style.
Besides The original GTR is a classic SUPER car
  • Replies 44
...the best examples of which will gather at Tench Ave Reserve, Penrith at 7-8.30am on Sunday 10th October
+ cruise...
+ cruise...
12-1.30pm at The Edge Cinema Katoomba for "Kory Leung Photography" photoshoot...
+ Screening of 1992 Bathurst 1000 on The Edge Cinema #1
+ 3x major gongs for R32s with each prize worth more than $200
+ Award Certificates signed by Terry Ashwood > can be co-signed by Jim Richards on 12th December at Trackside Rest't Gosford - another official SAU Event
+ Door prizes by Meguiars and Amorall
sigh... makes me wanna buy an R32 for this event :yes:
As has been mentioned before, you own it, you drive it, you love it, that's all that matters.
I will say something though and hopefully this makes you feel better. Doesn't matter what type of car you have/own/drive, you will always be discriminated against.
Drive a "dressed up poser" Lancer and people will give you sh*t because you don't own an EVO... ESPECIALLY EVO drivers... To them, you own a FEVO = Fake EVO.
Drive an SS and HSV owners will tell you, "I have one" which makes you all sad and sh*t thinking to yourself, "I just want one" *rolls eyes*
Drive a WRX and you'll either wish you had an STI or STI drivers will look down on you (not really but it does happen)
Drive a Porsche Boxster and everyone thinks you're a poor arse because you can't afford a GT2/GT3.
Drive a Skyline and people that don't know much about Skyline's will automatically ask you if it's a GTR. When you say, "no" they just nod and stop talking about the car because they respect you less, especially if they've never driven or ridden in a GTR to even know the difference.
I'm not saying this is all fact but it does happen and some cases are more extreme than others but you will always be discriminated against, at the end of the day, don't give two rats what anyone else thinks, be happy you've got what you have and get on with it. You're thankful for what you have and that's all that matters.
^ THIS+1
The other thing that brings you down is the stereotyping:
"What do you drive?" "Skyline" "You drive a ricer!" They're Japanese built wtf? Or you're instantly labelled a hoon.
"What do you drive?" "VN 5.0lt" "Then you have to be a bogan"
"What do you drive?" "VS Ute" "You're a red neck!"
"What do you drive?" "VL" "Oh My God Uleh, is it fully sick??"
Where did this crap come from? A person's car is their choice alone. And who got the idea that Skylines are 4 cylinder?
RAHgarblgarbl
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
