After some research i believe my s3 r33 gtr is making less power than it should, 162 AWKW.
Long story..Stock standard gtr, i removed the original exhaust and put a 3.5 stainless turbo back, everything was good...for a few hours. i put my foot down and i felt a hesitation in power, at that very moment i looked at the standard boost gauge, the boost was down and the engine immediately felt weaker. and still feels weaker. On a cold night the car some time gets very lazy, the boost on the standard gauge goes down and the car take ages to rev?? i have taken it to three different mechanics two of them gtr owners/tuners.
There is a small hiss coming from under the plenum, we covered the area in water but it still didn’t go away. One mechanic said that it cause that much of a power loss??
Anyway, we checked the following
Coils...Ok
Volt sensors on the exhaust..Fine
Air flow metres..Fine
Turbo... working fine
When on the dyno the boost level was fine?? (Even though my standard gauge is still down...how could my gauge fail at the same time i lost the power???)
vacuum leaks... none
Air/fuel...ok
Looked inside the cat..Ok
Compression...All 6 at 175
Removed the rubber hose and the spring is in the right place
Did a smoke test..Ok
Here i am few hundred dollars poorer, and still have the same problem??
Any input is greatly appreciated
What else should i check?
https://www.sau.com.au/forums/topic/337701-power-loss-all-standard-r33-gtr/
reset ECU by disconnecting battery for like 15 minutes. Also check vacuum line going to boost gauge, as if it is reading low perhaps there's a split/leak in it.
Jammed actuator(s) for turbos, or wastegate(s) stuck open. Give that a shot, as if they're open a little bit it will cause boost to build very slowly/the car will feel like a slug...what boost was it making and when did it make it?
doesnt explain the boost guage inop
Are you sure? I would have thought if the BOV's were being pushed open then all the boost would be blowing straight out.. Thus the Bov not reading properly as the air is not reaching the plenum.
Have a feel behind the back of the balance tube, the hose may of popped off or split in half that supplies the factory boost gauge's MAP sensor.
id be replacing all the standard vac/boost lines with silicone ones. they're old and brittle
ur symptoms point towards that too - hissing noise, loss of power & incorrect boost pressure reading
i had a similar prob with mine, when i installed my boost gauge a few days later it started doing the same things, obviously when i installed the T piece, the standard hose was brittle and split
what about lazy coilpacks? when its cold it pops & missfires
there is 10 to 20kw missing, i paid allot for this car, this is realy giving me the sh ts
what else could it be??
here is the plug, they reckon its about right
Instead of using water to trace the "hiss" trying using aerostart or similar.
If you have a vac leak (thinking gaskets?) your revs will rise at idle if you hit the spot with the spray. ie more fuel.
Gasket leak will also bleed boost at higher rpm.
Might be worth a try.
Cheers
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
