mrRS4 Posted September 21, 2010 Share Posted September 21, 2010 (edited) I got my timing done today at a workshop when i sit in park/drive or anything below 20km o can hear what sounds like a whining sound. Car starts first time no worries and still drives well drives better than b4 i got the timing done. Suggestions? Edited September 21, 2010 by mrRS4 Link to comment https://www.sau.com.au/forums/topic/337706-wierd-sound-after-timing/ Share on other sites More sharing options...
RubyRS4 Posted September 21, 2010 Share Posted September 21, 2010 I can't see how the 2 can be related. Did you do any other work at the same time? Would your brake pads just happen to be out of material coincidentally? Is sound coming from under bonnet or elsewhere? Link to comment https://www.sau.com.au/forums/topic/337706-wierd-sound-after-timing/#findComment-5459093 Share on other sites More sharing options...
SMOKEYV35 Posted September 21, 2010 Share Posted September 21, 2010 got your timing BELT done? or you got your timing adjusted...? if you suspect the two are related then i'd suggest popping the bonnet and have someone gently rev it from cold - it could just be a slipping belt that they need to tension up more. Link to comment https://www.sau.com.au/forums/topic/337706-wierd-sound-after-timing/#findComment-5459101 Share on other sites More sharing options...
nuR.spec Posted September 21, 2010 Share Posted September 21, 2010 timing belts on too tight.... Link to comment https://www.sau.com.au/forums/topic/337706-wierd-sound-after-timing/#findComment-5459107 Share on other sites More sharing options...
kidafa Posted September 21, 2010 Share Posted September 21, 2010 I can't see how the 2 can be related it could just be a slipping belt that they need to tension up more. Always be careful with timing as we all would be well aware of with chef's issues, Also be careful of what you read on forums. OVERTIGHT cam belt can make whiring noise. Gates belts are also known for being a tad noisy if thats what you put on? search it if so heaps of info on the issue. Idler and tensioner pulley bearings may also be a tad noisy while they bed in. Link to comment https://www.sau.com.au/forums/topic/337706-wierd-sound-after-timing/#findComment-5459121 Share on other sites More sharing options...
Bronx Posted September 21, 2010 Share Posted September 21, 2010 timing belts on too tight.... ^what he said or you have an added supercharger.... *crosses fingers* Link to comment https://www.sau.com.au/forums/topic/337706-wierd-sound-after-timing/#findComment-5459122 Share on other sites More sharing options...
mrRS4 Posted September 21, 2010 Author Share Posted September 21, 2010 Its under the bonnet. After having a quick read it sounds like a few things. Thinking timing belt is on too tight or slipping Going back first thing in the morning, Changes my plans but oh well trip to melbourne in the beast is going to be a bit later on. Link to comment https://www.sau.com.au/forums/topic/337706-wierd-sound-after-timing/#findComment-5459124 Share on other sites More sharing options...
mrRS4 Posted September 21, 2010 Author Share Posted September 21, 2010 Should have used the search http://www.skylinesaustralia.com/forums/Ti...noisy&st=40 Seems like its going to be ok. Link to comment https://www.sau.com.au/forums/topic/337706-wierd-sound-after-timing/#findComment-5459252 Share on other sites More sharing options...
chef_stagea Posted September 21, 2010 Share Posted September 21, 2010 get a hose, put one end to your ear... other end move around and ull pin point the sound... but yes gates belts are noisy Link to comment https://www.sau.com.au/forums/topic/337706-wierd-sound-after-timing/#findComment-5459303 Share on other sites More sharing options...
-RBD2- Posted September 21, 2010 Share Posted September 21, 2010 Didn't you have some strange noises coming from your engine bay after a timing belt change Adam? Link to comment https://www.sau.com.au/forums/topic/337706-wierd-sound-after-timing/#findComment-5459659 Share on other sites More sharing options...
mrRS4 Posted September 23, 2010 Author Share Posted September 23, 2010 Ok it was just tensioned up too tight so all fine now. Link to comment https://www.sau.com.au/forums/topic/337706-wierd-sound-after-timing/#findComment-5461614 Share on other sites More sharing options...
