anyone go to the summernationals yesterday or today? just got back from todays events and damn it was fun. 95% of the entrants were sub 10 second cars and by the end of the day an 8 second pass seemed relatively slow.
the highlight had to be the top fuelers. unfrickingbelievable! these things are scary fast. best time was a 4.8 @ 309mph by the rocket car. i'd never seen one run up close and the first time they flew past my hands just slapped my ears shut before i knew what had happened. you can feel your balls retreat inside your stomach.
track is run very professionally and looks like everything it was promised to be.
https://www.sau.com.au/forums/topic/33772-summernationals/
I went last yesterday arvo/night. I have to say i have never been a huge fan of drag racing until now. The highlight of the night was by far the Top Fuelers and as Two40 said, unfrickingbelievable!!@@!#!#!@. I have seen indy cars, f1 cars GP bikes everything but i have never experienced anything like the top fuel dragsters. Sitting half way up the hill i felt my hair been blown around and the heat hitting my face as they took off and my internal organs been shaken like they have never shaken before. Seeing the cars reaching just off 500kmh at the end of the 400m side by side has definatly turned me into a drag racing fan although i will always be a bigger circuit racing fan. The rest of the cars were good and as said before anything over an 8 second pass began to seem slow.
The other thing is the WSID is an excellent facility. We will be very lucky to have a facility like this in sydney which runs weekly street meets. The night also showed me that australia has alot of depth in drag racing. Although there are only really 6 top fuelers the rest of the classes seemed fairly full and the workmanship of the cars was awesome. (you were alowed to walk through all the pits, bloody good). Anyway. I had a great night and will be attending as many major events there as i can.
https://www.sau.com.au/forums/topic/33772-summernationals/#findComment-678110
went on sat arvo/night
was awesome, yes those top fuellers are amazing
the ground shaking, your vision blurred, your ear drums rattling and seeing something go from 0-500km/h in 4.8sec over 400m is the a must see
great facility, still being worked on in terms of crowd facilities etc, but going to get better and better
and from the crowd, drag racing is back in business in sydney
https://www.sau.com.au/forums/topic/33772-summernationals/#findComment-678532
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
