  • Replies 44
Should take no longer then an hour of labour if its a bolt on exhaust.
The process however, you may need to allow 2-3hrs as when you drop off the car the mechanics need to wait for the stock piping to cool down before removing. Usually charge around $80/hr so allow yourself at least $100 to be safe.
You could do the install yourself, saving you the cost of someone else doing it.
It would also save you the time of organising it to be done, and you can do it when you want.
A straight bolt on system is just that, you wont need to remove anything else because it is in the way.
Just unbolt at the flanges and remove the hanger rubbers from the old system, swap them over and the bolt in the new system into place.
As long as your not getting extrators it should only take a few hours.
I was gonna get these, put off by the 12 hr install time people speak of...
Ill have to do with HFC resonated and y-pipe!
OP: Google the install and do it yourself. There is nothing like knowing you did something on your own. !
Give Aaron from import monster a whirl,
depends on exchange rate etc but allow $2k-ish for product and delivery.
Import Monster Pty Ltd
3/6 Wigan Road
Bayswater VIC 3153
(03) 9008 0031
Edited by TUFF_350
I got mine from Hi-Tech Mufflers (Sydney)... Cat-Back stainless steel.
I can't remember exactly how much it was but was around the $2k range.
Left it in the morning. Went to the gym for a couple of hours and it was finished.
I felt power gains as soon as I took off from the garage. But I didnt get a dyno done.
Sounds good when in full flight but just had a nice hum when just cruising.
I guess just depends on how much noise you want to make.
is it much louder than stock at idle and cruising? I hear hitech supposedly has the best gains power wise, but is not much louder than stock...
always loved the HKS but i hear they drone so that put me off... atm looking to import motordyne from the states, seems as good as HKS but without the drone
Yeah I was really impressed with the power gain. Felt real good.
To be honest at idle, its not much louder than the stock exhaust maybe 2 db louder, but even louder on cold nights and you'll definately notice the exhaust when starting the car. I really like the fact that I can take a long drive and not get a head ache from it but still turn heads when I launch it.
Check out my recent Wakefield Track Day video:
Silver 350GT... First minute of the video you'll see me flying down the straight followed by 2 different cars with louder exhausts. Its a good comparison. Turn it up to hear the difference.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
