hey for those who have bought and installed a exhaust system on there skyline im sort of interested in getting one but just need to ask in general how much it cost you to put the system onto the car (how much the mech charged), cheers
https://www.sau.com.au/forums/topic/337743-exhaust-installtion-prices-question/
Done this many a time now.
Jack the car up, undo all bolts from turbo back. I had old one off and new one on within the hour.
Be careful where you go if you choose to go the mechanic route, I had an estimated quote of 3hrs labor at $110 per hour to fit a turbo back exhaust!!
If you've got the tools and a free afternoon save yourself the cash :D
EDIT: Cass, fit my exhaust to your car already, want to see how it goes for you ! :)
EDIT: Cass, fit my exhaust to your car already, want to see how it goes for you ! ;)
Need to find some gaskets first. I'm not like my brother and can tolerate driving around without exhaust gaskets for any longer than the time it takes me to drive around the block :(
Cat-back? Turbo-back?
If it's cat-back it's quite easy to do...
Agree. I put a new cat and a cat-back exhaust onto my gtr whilst it was on the ground in 30mins... Couldnt be arsed jacking it up :blink:
I did a full dump, cat and cat back on my r33 gtst in about 2 hours including time for the WD40 to sink in on the studs.
Cost - nothing! Did it myself without much pain :P
Need to find some gaskets first. I'm not like my brother and can tolerate driving around without exhaust gaskets for any longer than the time it takes me to drive around the block :)
Exhaust gasket cement.
um lols. i just cleaned the metal between the rear muffler and the piping forward and whacked it back together.
fiiiiine i'll get some cement and do it properlike
Using the theory that a leaking exhaust flows better than one with no leaks? :blink:
I used gaskets and cement, but originally when I installed it with AbboBob (ex SAU president), he said you can get away with vasalene if the exhausts fit up close enough, the vasalene will attract some of the carbon from the exhaust, the vasalene will then pull the carbon into any depresions and keep a hole sealed up (assuming it is only a small hole).
It worked for a year, untill I was bored and randomly decided to cement it up, I was skeptical at first but it worked for a year that I know of.
Best to do it properly though from the beginning, a good job will save you time in the long run
Call an exhaust shop.. Tell them what your interested in.. Get a price.. done..
YUp this is the easiest, and sometimes even the cheaper alternative, especially when you break the dump pipe/turbo exhaust flange bolts in the turbo flange and depending how unlucky you are you could be up for a turbo out job just to be able to drill the bolts out
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
    • @Wazmond you are correct, my bad, was not my intent    https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.    I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.    I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.    https://gtrfestival.com.au
    • Just buy a bunch of covers off aliexpress, they're like $5 each. Rattle-can them and stick them on as needed/fly off.
