cheers for the quick reply. Fast wouldnt happen to metion if its a lsd diff would it?
cheers
jnr
it will say in that options list on 1st pic, havnt had time to translate it, remind me on weekend.
thats cool
does it give any other info on my car though.
i really wouldnt mind checking its history
What would you like to know?
It was built November 20002 and has HID headlamps & Leather seats.
thanks for the help guys, i jacked the car up the other night and spun on wheel and sadly the other wheel spun the opisite way :D open centre
jnr
They always will with a viscous LSD. Cant check them the convential way of checking normal clutch plate or cone type LSD's.
Edited by kjb_r33
thanks mate, my guess was better than i thought!
what about ecu and diff ratios?
Your ECU part number is 23710-AQ803... which is different to my RS ECU (23710-AQ800)... both of which are different to an ARX ECU.
Not sure what you want to know.
Diff ratios? NFI. FAST does not give that kind of info to my knowledge
my 31 silhouette (factory cone type lsd) would both turn the same way
i had my stag on stands the other day and they both went the same way too...
how do you check for an aftermarket lsd?
or did the rs4s's come with gtr spec diffs? :P ?
You may be right, maybe its checking the BRAKEAWAY torque that cant be checked.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
