Ok, heres the deal.
My gtr is stalling on idle, spluttering etc only when warmed up.
Thought it to be a ECU issue with the power fc(Which when installed happens alot more frequent and worse) so i got the old ecu installed worked fine for a week.
Issue still exsists.
I have checked the Vac Lines and piping for leaks as far as i know there are no leaks.
I have cleaned the AFS with contact spray.
I have yet to check the Idle control unit.
I run a stock bov.
The car use to idle on 1200rpm however after issue only appeared after idle down to 9000/1000rpm from Godzilla after they fixed my timing to 20.
I have taken my car to Mercury and they did say it was either the Power fc or the wiring.
I got my stereo installed by WOW @ Underwood. Dodgy install dodgy products drivers side speaker blew and they tried to say i installed it myself (I Didnt)... anyways back on track when the car stalls it does not seem like it looses power the engine just dies could the wiring be stalling cutting ignition to the engine?
I have been told that it is a common fault with skylines that it does not return to idle very well. or that the altnerator does not charge correctly.
Can anyone help me?
https://www.sau.com.au/forums/topic/337754-help/
Sounds like an airflow meter to me, try swapping them one at a time for one you know works, While yours are now clean the fault could be on the solder inside it for example or like mine the wiring in the pug has come loose from the pins
https://www.sau.com.au/forums/topic/337754-help/#findComment-5459679
Thanks mate, Yeah im taking it to a Auto Sparky tomorrow to get him to have a look at it.
Cheers for the tip.
I thought it was the power fc looks like i can plug that back in :thumbsup: as soon as this is resolved lol.
https://www.sau.com.au/forums/topic/337754-help/#findComment-5459849
Wiring is fine, Suspecting a DEAD AFS. or its not earthing right, so tried some stuff and if that doesnt work new AFS will be coming.
Hey mate go to the ETC on your PFC hand controller and select sw/sensor - you will see o2.1 and o2.2 listed check what these are reading. They will be different but if one is way different to teh other tehn you can confirman AFM prblem.
https://www.sau.com.au/forums/topic/337754-help/#findComment-5462969
Can anyone help me?
lol. thats all i have to say to that claim.
So are you saying that after WOW installed your sound system, the car THEN went funky?
Can you give some advice as to how the events unfolded in chronological order?
I remember I had to adjust my idle thingy on the rb26 and all i can say is DONT take it off because it is a broad minded person to get back in. If you adjust it with a screwdriver, it may work for you, though I don't know if that is just a bandaid solution - still masking the original problem.
Jonnyo's postulation seems quite logical, if you dont have access to a multimeter - id give that a go first, since it is a non-invasive procedure.
Otherwise, good luck.
https://www.sau.com.au/forums/topic/337754-help/#findComment-5464932
When I first got my R33 a few years ago it used to hunt like mad and sometimes stall when pulling up to lights and stuff. I searched on here for similar problems and a few people managed to fix it after cleaning the idle air control valve. What happens is the spring inside gets all full of shit and doesnt open and close properly causing the car to hunt at idle. I took mine off and cleaned it all with carby cleaner and then adjusted the idle and that fixed the problem. Easy game.
https://www.sau.com.au/forums/topic/337754-help/#findComment-5478465
Here is the link to the guide I followed.
AAC Valve Cleaning Guide
This is done on an RB25 but there isn't too much difference between the two engines anyway.
Thanks, I just adjusted the idle and it hasnt not hunted since ;)
https://www.sau.com.au/forums/topic/337754-help/#findComment-5488011
if its still playing up re-install stock ecu and hook up a diagnostics tool to it, ask mercury or what ever shop u use, one should have one and it should be able to pull out a fault code, letting you know exactly the fault, my guess will be afm's most likely. very common problem, they just get old solder inside them and can be repaired, but most people exchange them or buy new ones at great expense. butr could be another issue with iac aswell? try them all, just go to the diy section and start searching for HOW TO: threads. its a process of elimination with skylines.especially when it comes to sensor problems, some or many may lead to the same out come, its just trying to find the correct one which is a bitch.
https://www.sau.com.au/forums/topic/337754-help/#findComment-5495047
  • 2 months later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
