Near New Tandem Car Trailer
Hardly used and now no longer required
Professionally made
LED tail lights
Long A frame (plenty of room for tool boxes or tyre rack)
Beaver tail (made for low race/drift cars)
Pull out ramps (very quick and easy design for loading)
Winch
Ford hubs and brakes (easy to find rims/spare parts)
Checker plate flooring and ramps
Hammertone paint
Jockey wheel
Fresh rego
Got sick of using hire trailers that towed badly and were painful to load my lowered drift car on to. The trailer was designed to make loading on and off a quick and easy process.
Most cars will be able to drive straight on without needing to remove the front bar (which was always an issue with hire trailers) and with a small gutter or hill you can pretty much drive any ant scraping lowered car on without removing the front bar.
I think Truscott and Nigel also have had their trailers made by the same guy so if you have seen either of their trailers it is of the same quality design.
First picture is of the actual trailer while the last two are of Nigels to give you more of an idea. Will get more pictures up of actual trailer asap.
Located in Horsham Victoria. May be able to meet closer to you if needed.
$3999
https://www.sau.com.au/forums/topic/337758-tandem-car-trailer/
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
