I've just brought a G-Tech, a week ago haven't played too much yet the 0-100 times haven't been too good though been getting mid 8's. But mines a heavy 4dr and thats with tool boxes, spare tyre, and the sub box still in the boot.
For the 1/4 mine has done 16 flat at the strip, on the G-Tech it's done 16.1.
Just got an Apexi RSM (not as acurate as a G-tech, but not bad) and i managed 8.6 to the 100, with full tank, subs+box and all the rest of the stuff most daily drivers are full of. haven't tried a 0-400 yet, but i don't think it wil be all that flash...
definately not as fun with out the gas in the car cause the timing is retarded, although my timing is at stock rather then retarded cause i normally run it at 19 degreese where as stock is 15 and u notice the difference in power, though if ur car doesnt have the timing advanced it wont make ne difference. If thats what u were asking. Other option is rb 30 with ur head, im putting my 25de head on a rb30 very soon, before i start ill strip back the rb30 replace bearings balance the crank and shot peen the rods and wack some new rings in. then ill hopefully be in the 14's without gas and definately below with gas so like mid to high 13's very soon.
ya tis first car, no one will touch me on a 32 turbs, im thinking ill get a 33 na, hide a nos kit in the partition between the boot, maybe a 5lb bottle, not sure
yo is 100hp shot safe :)?
also how many quater mile runs are you getting with the 75hp shot ?
have you checked out that zex pod filter with the n20 jet in the end, looks very interesting!
no 100hp definately no safe on a NA, 75 is probably pushing it but i got 14.08 at the test n tune tonight with a shit start and shit 60ft so im thinking i can break into 13's just if i get everything perfect.
Gearbox is the only thing im unsure about ill just see how it goes, seems to be holding up with the nos alright. Clutch is fine cause its a really tuff item i got put in a while ago. im hopefully getting an rb30 for free, ill have to pay for the rods to be shotpeened, crank balanced, new bearings and new rings and some extractors, all up like 600 dollars as i will do all the change over including porting and polishing my head myself with some help from my boss.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
