the quickest i ever got was 7.26 seconds, this was the most perfect launch revved to just 3000rpm and sort of ride the clutch abit then drop, got a bit of wheelspin. Shifted redline in 1st, then early in 2nd so i could hook away in 3rd as it is in the midrange area. i was shocked as i was gettin mainly 8.3 seconds all the time which was was my mates honda acord 2.2 SOHC was gettin :S and i was gettin cut at that
  • 2 months later...
just so you guys have something to compare to:
r33 series II manual with apexi rsm
0 to 100 5.70
stock standard, just good tyres and a pod filter (no cold air kit etc..) and a 4" muffler, stock exhaust
yeah for sure. just thought i'd give you guys some figures to compare to. i have stacks of fun in my turbo. much prefer it vs non turbo and alll ive got is a pod filter so you can hear the turbo wind up and the factory bov. sounds sweet as. my peak is 141rwkw as per dyno run with stock everything, normal gtst is stock 125rwkw so im a little bit more, not sure why. rb25det with 96000 on the clock
yeah its better than the turbo specs, funny that he only has 75horsepower nitrous.
the stock turbo is 6.10 or thereabouts according to most magazines, or 6.18
as a reference the brand new police cop car hsv gto 5.7 litre v8 does 0 to 100 in 5.8
well the one holden lent the cops for trials in vic anyway plates are "HSVGTO" which is used exclusively for the cops does it in 5.80. my friend got 5.70 in my car, i can only manage 5.98
yet to try again, maybe i should soon :)
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
