Hi Guys,
Up for sale is a Brand New 6-Boost Manifold for an R33 GTS-T with any flange - Brand New, in the box with the nuts, washers and gasket. -
Price: $1,200
Long story short, I recently decided to upgrade to a 6 boost manifold for my r33 GTS-T, and paid for it in full, however, something personal just came up and I needed the money back, and I asked if I could get a refund but Kyle from 6 boost had already started on the manifold, so, I could not get my money back, which is fair enough.
Now, he has not yet started working on the flange, so, I asked him to hold off on making it until I find a buyer, once I find a buyer I'd let him now what flange to put on it.
I paid $1,400 for this including postage.
I am asking $1,200 which is quite reasonable.
Let me know if you're interested ASAP otherwise I will try elsewhere to sell it.
Cheers Guys!
https://www.sau.com.au/forums/topic/337820-fs-6-boost-manifold-for-r33/
Hi Guys,
Price: $1,200
Cheers Guys!
hey does this fit the r26 too?
Hi guys,
To clarify and try and help Turbz out of an unfortunate situation, I am happy to build the manifold high or low mount, T4 or T3, single entry or split, in any position you like for whatever price you work out in the sale with him. For security of payment, once you have paid him for the manifold, send me a copy of the payment receipt and I will ship the manifold directly to you myself, cutting out any question to the legitimacy of the seller or delivery. It may take up to 10 days to build what you want, however I do have a T4 RB25 manifold on the shelf for immediate dispatch.
Hope this helps you out mate, just so you know freight will be at yours or the buyers expense :)
6BOOST
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
