hi, just got my new car........How much oil goes in when you fully drain it and new filter.......getting shoulder surgery tomo so i need to service it tonight but i don't have any books that specify how much oil to use
cheers fella's
(i did a quick search but came up with nothing and i;m running out fo time!!!)
  • Replies 73
Fill til it comes out the filler plug...that's what it's there for. For obvious reasons you won't be able to put any more in!!!
where is the filler plug? never heard of that...but anyway i thought it was 4.8l and 5l is good to put....could it be diff for rb26 or its the same for rb25 too...
Might be different on GTRs but it's usually on the side of the gearbox, not far from the slave cylinder.
Just put in 4L, start the car, switch it off and keep topping it up until its at full. 5L is far too much.
I can get 4.8 - 4.9 L perfectly in the middle of the dipstick if I jack up the back/passenger side of the car and drain out everything, I dont think 5L is way out there.
never knew that...ill check of that now in the weekend...would it be in other cars too? like commodores?
i've always found in the stag s2 rb25neo turbo, it fills my draining tray including the filter to about 4.9 - 5l right on the line.
(depending how much spills in the process on the front diff)
and my dipstick is always bang on the H mark.
now you've just reminded me i've gotta do a change this weekend.
Edited by Stagea_Neo
I change mine Every track day I put in 5l , Been doing this for 2 years now ... :blink: runs sick
I always filled 5L too...never hade any issues...when Jezza-gtR said 5L is too much i started to get worried..lol...thanks for confirmation...
the sump takes 4.5 litres
but for a track day it is advisable to overfill by 500ml - 1lt to help prevent oil starvation
i usually just throw in 5lt
OOPS was talking about gearbox fluid lol. Got it confused with another oil replacement thread :rofl:
OOPS was talking about gearbox fluid lol. Got it confused with another oil replacement thread :)
:yes: ..you got me all confused and was looking underneath the car like a dumb idiot...lol...y didnt i read this thread before i did it...lol...
sorry guys, didn't wanna start a new topic..
but what oil do you guys use?
sure there is couple of threads about what oils to use...do a search you might be able to find more info...
to answer your question i use castrol edge 10w-60 since its been recomended by my mechanic...
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
