I'm thinking of getting an oil filter relocation kit so it will make it way easier for me to change the filter when I do oil changes.
However I wanted to know if there were any downsides of having it? Would oil pressure be effected?
Also for those who have it, what kit/brand did you buy and how much did it you pay?
https://www.sau.com.au/forums/topic/337845-oil-filter-relocation-kit/
Why? it's really easy to do compared to most performance cars. You should see my mates soarer, and I think the 300zx's are pretty hard too. I know it's a little tricky to get some good force down there to take it off but there are plenty of tools which attach to a ratchet to help with that. In terms of effort, it is certainly a lot easier than geting under the car to undo the sump plug.
Also many aftermarket filters (drift, k&n) have a socket fitting which makes the job infinitely easier and saves a bit of knuckle scuffing.
Just my thoughts, but there are so many upgrades which are worth spending the money on before something like that.
Best servicing mod you can do. Any GTR owner will agree.
GREX kit here, $185 delivered, works great, makes filter changes so much easier.
There's one for sale by elrodeo666 in the for sale section right now.
Thanks N1GTR, I'll have a look and see.
And yes, the GTR's oil filter is in a real bullshit position to get to. My GTR is a daily driver, so doing a oil change every 5000km's is going to be a regular thing for me so want to make it easier.
+1 on the relocation kit for my stagea, it originally sits in the biggest bullcrap position ever, cant do it from underneath because the front diff and driveshaft are in the way, cant do it from the top because everything else is in the way. you can pull it off by hand with a bit of effort, but the oil spills over your front diff is horrendous even when you try to cover it all up.
Fitted a J/J relocation/cooler kit to a 33 GTSt.
No noticeable change to oil pressure.
Not the best product, but it's cheap.
There's better, more expensive gear available and that's what I'll be fitting.
So much has to be removed to fit the adaptor, you want it perfect first time.
If you can't remove the oil filter by hand then you have used too much torque when you put it on in the first place.
It is a pretty common mistake that people make.
I only ever do mine up hand-tight and always need to use a tool for removal, probably because the engine and oil is all warmer when I take it off
Edited by Galois
Is the oil filter on the driver's side, middlish area of the block, sort of under the intake plenum? or is that just 25s? I was thinking about one too as the only problem I have is because it is horizontal I pull it out and try to keep it as vertical as possible but always get couple 100ml of oil spilt.
I also only do them up hand tight and can ALWAYS get them off hand tight... another little tip when putting them on... take a small amount of oil on your finger and just run it around the edge of the filter before you put the new one on... you can tighten it in further by hand and remove it easier later on.
Thanks for all the replies. Good to know I'm not the only one who feels the same about their GTR filter location :D
Looked on JustJap...
The GREX/Trust kit looks great. $389.00. Also the Cooling-Pro kit with the 7 row oil cooler is the same price. Hmmm...
I'm assuming the GREX/Trust kit would be higher quality? Is it worth the extra hassle installing the Cooling-Pro kit?
I don't usually cheap out on quality, so if GREX is better I'll settle for it. Besides, my oil temp always sits between 80 - 90°C so I'm guessing that's fine?
Found elrodeo666's 2nd hand GREX kit for $170 delivered, but looks like he's already sold it... Gutted :)
Where did you get yours for $185?
Sorry if I'm rambling btw lol :P
Got it from a guy who was stripping his car. Best bet is to send elrodeo666 a PM to make sure it's sold, that would be my first move. Then if that's no go, then I'd keep a very keen eye on the forums for one coming up and jump on it. Don't spend $389 on one
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
