I am preping the car to do a little track work (propably 4-5 times a year), nothing serious, just wanting to have a little fun in a controlled environment.
I am considering removing the Hicas as many people have recommended doing, but b4 doing so i would like to get a couple of issues cleared up.
1/ If the car handles better without the HICAS why was it installed throughout the 32, 33 and 34 models?
2/ If the fuse is taken out for track days, is the HICAS firmly locked in the neutral positon?
3/ On a R33 what methods can be used in disabling/removing the HICAS?
4/ Can anyone please supply links to suppliers that have kits for R33's?
Thanks
Alan
https://www.sau.com.au/forums/topic/33786-r33-hicas-removal/
Hi Alan, this has been discussed a great number of times I suggest you do a search. In the interim brief suggestion follow your questions......
Wally factor. It makes the car safer for the wallys, it doesn't make the car handle better. I have a question for you, if HICAS makes the car handle better then why is there none, zero, zilch, SFA, race cars with HICAS?
2/ If the fuse is taken out for track days, is the HICAS firmly locked in the neutral position?
No
Replace the rack with a tube and screw the std steering links into the tube. Or buy a kit from Tomei which has washers that you stick in the ends of the rack to stop it moving. We replace the rack as it is lighter.
If you have replaced the rack then remove the hydraulics, it also saves a lot of weight. If you used a Tome kit then you do nothing else but plug in the electronics box that tricks the dash warning light.
If you have replaced the rack and removed all the other useless parts then remove the HCAS warning bulb from the dash as it will stay on.
Try the Tomei outlets, I use these guys.....
www.hioctaneracing.com.au
Hope that helps
https://www.sau.com.au/forums/topic/33786-r33-hicas-removal/#findComment-677813
Thanks :D
Have recently read a thread relating to the R32 hicas system and it's removal. You also stated the removal of the hydrolics in that thread.
Does the R33 HICAS work hydrolicly? I thought that only the 32's had a hydrolic system, as the 33's and 34's were upgraded to a fully electronic system.
I am cosidering using the TOMIE system as it can be easily reverted back to normal if need be. Also wouldn't the removal of about 30kg of parts effect the "balance" and front to rear weight distribution of the car, thus effecting it's handling.
I am just trying to get educated on such matters :(, i am in no way trying to 2nd guess your tactics, as your knowledge and experience is FAR greater than mine.
Thanks
Alan
https://www.sau.com.au/forums/topic/33786-r33-hicas-removal/#findComment-677824
Would installing the TOMIE HICAS lock kit damage the system? Just thinking, if the shims prevent the HICAS from moving, would it cause great strain on the mechanics or does the electronic box disable the system completely (kills power to the HICAS)?
https://www.sau.com.au/forums/topic/33786-r33-hicas-removal/#findComment-677839
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
