I am preping the car to do a little track work (propably 4-5 times a year), nothing serious, just wanting to have a little fun in a controlled environment.
I am considering removing the Hicas as many people have recommended doing, but b4 doing so i would like to get a couple of issues cleared up.
1/ If the car handles better without the HICAS why was it installed throughout the 32, 33 and 34 models?
2/ If the fuse is taken out for track days, is the HICAS firmly locked in the neutral positon?
3/ On a R33 what methods can be used in disabling/removing the HICAS?
4/ Can anyone please supply links to suppliers that have kits for R33's?
Thanks
Alan
https://www.sau.com.au/forums/topic/33786-r33-hicas-removal/
Hi Alan, this has been discussed a great number of times I suggest you do a search. In the interim brief suggestion follow your questions......
Wally factor. It makes the car safer for the wallys, it doesn't make the car handle better. I have a question for you, if HICAS makes the car handle better then why is there none, zero, zilch, SFA, race cars with HICAS?
2/ If the fuse is taken out for track days, is the HICAS firmly locked in the neutral position?
No
Replace the rack with a tube and screw the std steering links into the tube. Or buy a kit from Tomei which has washers that you stick in the ends of the rack to stop it moving. We replace the rack as it is lighter.
If you have replaced the rack then remove the hydraulics, it also saves a lot of weight. If you used a Tome kit then you do nothing else but plug in the electronics box that tricks the dash warning light.
If you have replaced the rack and removed all the other useless parts then remove the HCAS warning bulb from the dash as it will stay on.
Try the Tomei outlets, I use these guys.....
www.hioctaneracing.com.au
Hope that helps
https://www.sau.com.au/forums/topic/33786-r33-hicas-removal/#findComment-677813
Thanks :D
Have recently read a thread relating to the R32 hicas system and it's removal. You also stated the removal of the hydrolics in that thread.
Does the R33 HICAS work hydrolicly? I thought that only the 32's had a hydrolic system, as the 33's and 34's were upgraded to a fully electronic system.
I am cosidering using the TOMIE system as it can be easily reverted back to normal if need be. Also wouldn't the removal of about 30kg of parts effect the "balance" and front to rear weight distribution of the car, thus effecting it's handling.
I am just trying to get educated on such matters :(, i am in no way trying to 2nd guess your tactics, as your knowledge and experience is FAR greater than mine.
Thanks
Alan
https://www.sau.com.au/forums/topic/33786-r33-hicas-removal/#findComment-677824
Would installing the TOMIE HICAS lock kit damage the system? Just thinking, if the shims prevent the HICAS from moving, would it cause great strain on the mechanics or does the electronic box disable the system completely (kills power to the HICAS)?
https://www.sau.com.au/forums/topic/33786-r33-hicas-removal/#findComment-677839
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
