hi all
wondering if this thermo wrap is actualy any good? seen a few cars supporting it
would like to head from anyone whos done it, brands to stay clear of, power increases, or any other bits to add to the melting pot :P
im unsure as to how it works on exhaust... is it to keen the head in the manifold/pipes, to reduce heat soak to pre engine bits, or are there other reason...
also i rarely see intercooler pipes with any on it...
:blink:
https://www.sau.com.au/forums/topic/337860-thermo-wrap-is-it-actualy-decent/
if your exhaust is mild steel then stay away from wrapping it. seen a few cases of front pipes rusting out fairly quickly(even to the point of my mates 13BT front pipe collapsing in on itself).
Ceramic coating is the way to go for ultimate heat protection
Wats the reasoning for such serious fast rust??
I think my catback is but 99% of front pipes are stainless... Much reason u wd do the catback anyway??
hi all
:blink:
Heat wrap/ lagging is predominantly used to protect surrounding components from heat damage in the case of exhausts. There is an amount of evidence to show keeping the heat in the pipes also improves gas flow due to higher temp as opposed to cooling (shrinking) gas where heat is shed. I'd stay away from heat wrapping intercooler pipes, unless they were routed near the exhaust, the pipe will shed heat better without it.
I'm just using steam pipe lagging on my dump & front pipe, it was easily available to me through work, and performs the same as any other type of "specialist " heat wraps for cars.
Resist the temptation to paint it though, you will be subjected to a life of burning paint fumes until you finally give up and remove it; as my friend found out...
+1 with Big Fella on mild steel, use only on stainless.
my understanding was that it was more the domain of cars with high mounts and big tuned length manifolds that put a lot of the 'hot bits' quite high up in the engine bay etc - and obviously cars that are doing serious work. all the reasons above obviously apply. other things can be as simple as it protects the paint work from being damaged from heat exposure as well as other plastic and rubber bits that live in engine bays.
i guess there would be an arguement that it would keep underbonnet temps down on a stock car, but i think a simple cold air feed would probably do more and be better at overcoming heatsoak.
the stuff is also frightfully expensive! i think your money is better spent elsewhere unless you're planning on a 35/40 highmounted to a 6boost, but if you ARE then go for it!
for the cost, you may as well get the stock cast manifold hpc coated inside and out
like some ppl said, it keeps the heat in = larger volume of gas = faster gas flow
will also cool down your engine bay no end
get your dump done at the same time, thats about the only sections to worry about getting it done to
So blue mesh would be a better option roo??
:D
So it would do more holding heat in, than protecting it in i/c piping??
Im not in the market for it, just saw a bit if it and wanted to know more about it,
And yes yes its not cheap!
It adds 10+kw. Tough as >_<
ceramic coating and heat wrapping do 2 very different things and you need to be aware of which one you are chasing.
Ceramic coating is a heat barrier that inhibits heat transfer to other parts of the engine (ie exhaust manifold to cylinder head) because, as we all know, heat = less power (inside the air pump we call an engine, anyway) Used on the entire exhaust side of the engine process, it forces the exhaust to carry away "waste" heat and not let it soak into the engine, whereby forcing undue load on to the heat exchange cuircuit.
Thermo wrapping of exhausts is a different kettle of fish altogether, and especially on race cars, is not there to stop the heat being absorbed into other engine components, its to keep the heat in the pipes. If it was to stop radiation then simple waffle shields would be used (like on factory set ups) combined with an efficient CAI setup.
The main reason for its use is because a gas's volume will increase in proportion to its temperature, which in turn increases its pressure. Exactly how much benefit this would provide in a turbo charged car I am yet to be convinced of, but in a NA application, when combined with a free flowing exhauist and a well designed set of extractors, it increases pulse scavenging by a huge amount, which in turn provides many ecomony and power advantages.
is this to say you are not suppose to ceramic coat and thermal wrap the entire exhaust side?
because wouldnt it be a double hit if you do a coat and a wrap?
wow quite a can of worms ive opened here :blink:
so are we kinda agreeing that its not worthy of putting on an exhaust of a street style car??
i was kinda looking at ways to stop heat soaking into the intercooler pipes and alike (pre-engine components obviously)...
would you attack this by stopping heat coming off the exhaust, and leaving the cooler alone, or would you wrap the cooler pipes... while locking in what heat is there while your at it...
No, definitely worth putting an exhaust on a street car.
If you want to insulate pipework post intercooler, go for it, I'd resist insulating pre intercooler; you'll be able to shed some heat there.
Just zorst manifold and dump pipe...?? My cat back isnt stainless so more money than its worth there... And with cooler i was just thinking as it came back into engine bay...
Do u just do a single layer or over lap effectivly giving u double layering
On mine; I insulated Dump, and front pipe, leaving cat exposed, with a 50% overlap, this took me to level with the back seat. Again, you mightn't want to get that excited, my wrap was free :blink: . Do your exhaust manifold if you like, I'd be happy with the factory heat shield in most cases.
Hey,Chef ,I had the same doubt as you so my cheap ass solution was the ACL heat shield, still hot around but not direct radiant from my Xforce ss dump pipe,did it about 8 months ago ,so far so good ...
Cost me $45 +$5 on ss ties, you can see it in the second pic ...
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
