Hey
I have a 1993 Nissan Skyline GTS-t up for sale, The last of its kind before they changed to the R33
- Has rego till April 2011
- 113 xxx
- RB20DET
- Power Windows, Steer and Mirrors
- 17' x 9' wheels with heaps of tread
- Frontmount intercooler
- Turbosmart BOV
- Cold air intake
- 3" dump pipe into a 3.5" turbo back exhaust
- Lowered
- Central locking and keyless entry
- Mongoose Alarm system
- Greedy Turbo timer
- Garret Boost gauge
- Strut Braces Front and Rear
- Pioneer head unit, Alpine type R speakers
- Heaps of spares and stock parts to go with it
- Plenty more that i probably have forgotten
- Car runs great, never given me any problems, great clean looking car. Will be sad to see her go, has been my pride and joy for sometime and very well looked after with nothing spared. All engine plates match with body plates and low genuine kms, unfortunately it's time to down grade and get a little buzz box >_<
- Car is located in Armidale NSW
- Chasing $8100
- Will consider trade if you have something of interest
- price is ONO, so throw some offers or trades this way and ill get back to you
- Contact Tom on 0423501078
- Pictures on request
https://www.sau.com.au/forums/topic/337881-93-r32-gts-t-skyline/
pics would be good. Would you consider swapping for a 2000 model turbo pulsar sedan - engineered, long nsw rego, 140kw.
http://www.skylinesaustralia.com/forums/00...sw-t333927.html
PM me or post in my thread if interested
Edited by gregor
The car is Black
Can someone inform me on how to post pics.... Sorry
im chasing something non-turbo, sorry mate, looks good tho
goodluck with the sale
Pics can be found here!
http://www.carsales.com.au/all-cars/privat...ion_String|GCLT -30.43051,151.7179 74.8&__Ns=pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|1||pCar_Make_String|0||pC
ar_Model_String|0&keywords=&__N=1216 1282 4294963846 4294963593 408&distance=25&silo=1011&PriceTo=408&seot=1&tsrc=allcarhome&__Nne=15&trecs=2&Cr=1&__sid=127B065495A0
  • 1 month later...
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
