This is one of the reasons I just spent a fair bit of dosh on a LSD
no more trying to take off quick @ the lights or at a intersection to avoid traffic only to get slowed down to a crawl and sometimes be in a dangerous situation... iv actually been pushing the VDC button when I know I have to take off quick for this reason
If you dont mind me asking, where did you get your LSD from and how much?
I wouldnt mind investing in one even though our cars already have LSD - but its a Liquid something LSD...
How about waiting for a suitable gap instead of squeezing in..
If this was a perfect world your comment would have been valid... but it's not.
If your cars an auto then its got an open diff
$1850 including delivery to my door + all customs and taxes paid etc
then im going to have to pay another hour or 2 for labor to get the workshop to install it
I could have got a cheeper jap brand mech 1, 1.5 or 2 way LSD eg nismo/kazz but I wanted something that didint make noises and need regular oil changes so I went quaife
hmm that module is an intresting way of tackling it.
I just put a single pole switch and rigged it up to switch power on the orange wire (12v) on the g sensor under the arm rest as stated on g35driver forums. Works good.
Thats all i did, its quick cheap, and disables the VDC completely, so no problem getting the rear end out, or doughnuts if thats your thing, in fact i haven't turned mine back on again, and probably wont, unless it snows :P
mine kills the power even when its not enough to spin the wheels.. its bloody dangerous.. plus whats the point of having a performance vehicle if you need to drive it like an Excel
    • I would hope so. I worry that it also might depend on whether the person working on the claim has had a good day or not. I could imagine that for example modified brakes would be an easy thing to point to for affecting the outcome of an accident. I don't know. I will keep paying my premium and hope for the best. But at the same time keep safe distances, drive defensively and avoid dickhead P-platers in lifted utes
    • I was just working on the assumption that a cammed V8 is significantly less polluty than a Japanese I6 turbo was at the way they tested it in an IM240. Perhaps I'm wrong! Perhaps cutting one of the readings I got in half is a tall order. I don't know too many people who actually got their cars emission tested with a RB to really compare the data.
    • I thought it was just if “the modification effected/caused the incident”
    • Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
    • You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here. It won't be the actuator. It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
