maybe one day i'll make the move! i do like steak..
My point is only if you have two to chose from in the beginning steer the other way.
If its in there already and its working for you dont bother changing.
Kristafa: did you get your AWD to work with yours, and if so, then how?
I have pretty much the exact same problems PM-R33, 18L/100 sucks, so does having to replace completely carbon fouled plugs every 10000km. My smokescreens are incredible on WOT, good for tailgaters though LOL.
I have pretty much the exact same problems PM-R33 HAD, 18L/100 sucks, so does having to replace completely carbon fouled plugs every 10000km. My smokescreens are incredible on WOT, good for tailgaters though LOL.
:laugh:
Edited by PM-R33
Dude thats just a shit tune. I know microtech's are a bit ancient compared to some other stuff but you can still get them to work well with a good tune.
I have none of these symptoms, and as before i average 13L/100km give or take. Guess i have a good tune :P
Mine is in a RWD bmw..
Link G4/Vipec V44, Haltech E11V2
Don't touch the Microtech, you will regret buying it, I did...
I regret using a power fc lol they had there place 10 years ago. I have not missed my power fc one bit since it went to a new owner.
For the price you can't go wrong with the ViPec. As with Phil i totally agree.
Fuel cut for rpm limiter on power fc :down:
Also did i mention i hate air flow metre's? You will skip that issue with micro tech but definitely wouldn't recommend going down that path of essentially using a game boy advance to run your car
Edited by Weapon
If you have ever seen one with a "good" tune please let me know, because I know of 3 other cars with Microtechs locally which have the exact same symptoms.
This is also running a tune from CRD.
whats your altitude?
    • The values for HID colour are also defined ~ see https://www.legislation.gov.au/F2006L02732/latest/text  ~ goto section 3.9 onwards ....
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
