I have a T28 Bush bearing turbo from ADM S15. Last came of a car with 90,000km.
Comes with actuator and oil drain pipe (differs to t25g). No intake/hotpipe snorkels.
Minimal shaft play, or what you would expect from a bush bearing turbo that has done this many kilometres.
Good upgrade from t25g. May also have S13 Redtop standard lines to suit (oil feed / water feed/return)
$400 firm.
I have a set of Super ADVAN rims.
Specs are;
17x8 +31
17x9 +31
5 Stud
To suit S13/S14/S15/R32/R33 GTST etc
$400 FIRM
Please SMS / call on 0438 010 323
    • Best practice for any track day should be Bleed brake fluid, inspect rotors and pads maybe even flip pads if they are prone to tapering.  Quality pad (project mu, endless, hawk, winmax, ap), Good high carbon content rotor (dba4000/5000, Ap, projectmu), Quality fluid, Good air supply over the rotor and caliper are all required for best performance at a track day no matter the car.  Even the bedding in of the pad and rotor is key to longevity. I've seen so many rotors destroyed on their first track day due to it.
    • The hardcore tracks1ut guys I know would flush their brake fluid every 6 to 12 months depending on the amount of track work they did. Unlike most of us SAU guys, probably flush it once a decade 🥲
    • Now that these are NLA, I suspect the answer is going to be to 3D print the plastic bit and glue on some felt or something to replace the brush. I have one or two of them (new) in the shed to go onto the car at some point. I could put some effort into measuring them up and could attempt to draw up the printed part in FreeCAD, if there is interest.
    • Hey team, the R32 ones look different to the R33 and 200SX ones. Also they're sold out on Amayama, looks like some dealer cleaned up the stock.
    • Might have to @Dose Pipe Sutututu him
