R180 to R200 is not a simple exercise. The 4 main bolt holes will need to be Lower, and more forward.
Bottom line is custom modification to the rear cradle.
I have a mate who has a R200 setup ready to go into a MR30, may be able to take some pics to clarify what is needed.
Secondly, how much power are you hopeing for to actually need a R200 diff??
oh and congrats on the project, much jealous
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5462955
Just in addition to above, I thenk there is a 'short nose' R200 then a 'long nose' R200,
Will have to verify, but the 1988 Z32 R200 will bolt in, with the only major hassle is the tailshaft flange needing changing to suit the bolt holes. (different PCD)
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5463302
and you forgot the axles, are you going to stay with the U-Joint type, or move to the CV-joint type ?
and it does look nice, are they new front guards ?
also I hope you have the glass to go with it.
Edited by noddle
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5463304
This is Kents old car he brought another one to start again, im thinking of sticking with his RB26 and RB25 gearbox idea. Dont know much about diffs, kent showed me the custom rear from SWR which is what im thinking of grabing. Yer has been over a year looking now i also have a 4 door which will become a parts car now,
I have all glass and most parts i think.
Passin, i think the diffs are the same.
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5464161
It does feel like we're getting railroaded presently but no blk180, i work for Alcoa World Alumina. We didn't strike in the end although the shift before me walked out for the full 12 hours. I still have to work Sun & Mon but will def post all info on Tues with pics. Nice project by the way and good luck with the rebuild. My 210 is now officially a V8 but no quicker than my ex triple webered 6. These 308's don't rev much but that'll soon be sorted.
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5465668
post-44326-1285654594_thumb.jpgpost-44326-1285654302_thumb.jpgpost-44326-1285654696_thumb.jpgChanging from R180 to R200 LSD Longnose. The half shafts pictured are 260z ones, these replace the R180 shafts.
The moustache bar was custom made using the rubber torsion parts from the R180 moustache bar.The R180 is totally different fit for the R200.
The flange that joins the diff to the drive shaft was also swapped for a 260z one, just undid the 22mm nut (approx) with an impact gun and refitted the 260z one. It's not that hard to do, it's just sourcing a few parts and making sure you measure up right for the custom moustache bar.
From memory the R200 was $ 900.
moustache bar $ 80
Half shafts and flange $70.
Hope this helps to make up your mind on the swap
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5469909
Is it a long or short R200 i also have been told that some come with 12 or 14mm bolts or something like that. Yer SWracing do the moustache bar for 240ks so will grab one of those. Really not sure what to do everyone telling me to go L28 so mite seach my local wreakers see if i can find one close.
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5472755
R200 longnose - 10 or 12mm ring gear bolts. Only relevant if you're swapping internals around.
Longnose R200's were first seen in the the 260Z, and last seen in the R31 (and equivalent vintage alternative models). 3.90:1 LSD's were fitted to DR30's, 4.375:1 LSD's were fitted to HR31's and I think that 4.11:1 LSD's were fitted to Leopards (or something like that!)
Don't hold your breath on finding one these days and consider that lots of work has been happening (esp. in the US) regarding the use of ~2006 WRX VLSD/CLSD R180 centres in Nissan applications.
The R180 isn't weak, and is lighter than the 200. I would be passively looking for one, but I think that there is plenty of other work needed on the C110 before it's on the 'must have' list :P
(yes my 240Z and DR30 have R200 LSD's, so call me a hypocrite if you must!)
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5474047
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
