R180 to R200 is not a simple exercise. The 4 main bolt holes will need to be Lower, and more forward.
Bottom line is custom modification to the rear cradle.
I have a mate who has a R200 setup ready to go into a MR30, may be able to take some pics to clarify what is needed.
Secondly, how much power are you hopeing for to actually need a R200 diff??
oh and congrats on the project, much jealous
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5462955
Just in addition to above, I thenk there is a 'short nose' R200 then a 'long nose' R200,
Will have to verify, but the 1988 Z32 R200 will bolt in, with the only major hassle is the tailshaft flange needing changing to suit the bolt holes. (different PCD)
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5463302
and you forgot the axles, are you going to stay with the U-Joint type, or move to the CV-joint type ?
and it does look nice, are they new front guards ?
also I hope you have the glass to go with it.
Edited by noddle
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5463304
This is Kents old car he brought another one to start again, im thinking of sticking with his RB26 and RB25 gearbox idea. Dont know much about diffs, kent showed me the custom rear from SWR which is what im thinking of grabing. Yer has been over a year looking now i also have a 4 door which will become a parts car now,
I have all glass and most parts i think.
Passin, i think the diffs are the same.
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5464161
It does feel like we're getting railroaded presently but no blk180, i work for Alcoa World Alumina. We didn't strike in the end although the shift before me walked out for the full 12 hours. I still have to work Sun & Mon but will def post all info on Tues with pics. Nice project by the way and good luck with the rebuild. My 210 is now officially a V8 but no quicker than my ex triple webered 6. These 308's don't rev much but that'll soon be sorted.
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5465668
post-44326-1285654594_thumb.jpgpost-44326-1285654302_thumb.jpgpost-44326-1285654696_thumb.jpgChanging from R180 to R200 LSD Longnose. The half shafts pictured are 260z ones, these replace the R180 shafts.
The moustache bar was custom made using the rubber torsion parts from the R180 moustache bar.The R180 is totally different fit for the R200.
The flange that joins the diff to the drive shaft was also swapped for a 260z one, just undid the 22mm nut (approx) with an impact gun and refitted the 260z one. It's not that hard to do, it's just sourcing a few parts and making sure you measure up right for the custom moustache bar.
From memory the R200 was $ 900.
moustache bar $ 80
Half shafts and flange $70.
Hope this helps to make up your mind on the swap
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5469909
Is it a long or short R200 i also have been told that some come with 12 or 14mm bolts or something like that. Yer SWracing do the moustache bar for 240ks so will grab one of those. Really not sure what to do everyone telling me to go L28 so mite seach my local wreakers see if i can find one close.
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5472755
R200 longnose - 10 or 12mm ring gear bolts. Only relevant if you're swapping internals around.
Longnose R200's were first seen in the the 260Z, and last seen in the R31 (and equivalent vintage alternative models). 3.90:1 LSD's were fitted to DR30's, 4.375:1 LSD's were fitted to HR31's and I think that 4.11:1 LSD's were fitted to Leopards (or something like that!)
Don't hold your breath on finding one these days and consider that lots of work has been happening (esp. in the US) regarding the use of ~2006 WRX VLSD/CLSD R180 centres in Nissan applications.
The R180 isn't weak, and is lighter than the 200. I would be passively looking for one, but I think that there is plenty of other work needed on the C110 before it's on the 'must have' list :P
(yes my 240Z and DR30 have R200 LSD's, so call me a hypocrite if you must!)
https://www.sau.com.au/forums/topic/337924-c110-coupe/#findComment-5474047
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
