first a quick run down of whats going on any help would be great as we have exhasted all options.
its on the dyno getting a tune the A/F perfect 12.0 threw the rev range but just excess fuel black smoke coming out of the exhaust.
now we have changed O2 sensors on the dyno A/F reader also borrowed another one from another tuning shop down the road, both read fine and identical when charts compaired. pulled my car off and put a differnt car on the double check and the sensor is reading perfect.
now there is no power loss and response is great but just excessive black smoke and fumes/fuel you can smell it.
put a brand new O2 sensor in can come out black as f*** also changed plugs after and where realy carboned up.
run down on engine
fully forged
head work
cams tomie b
-5 turbos
pfc pro
z32 afm's
full race twin kotomoto exhaust
dumps
hard piping kit intake and cooler
blitz bovs
hks twin power cdi
yellow jakets coils
800cc sard
tomie reg
044 surge tank
hks cam gears
any ideas would be great cheers
https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/
its twin seperated from the turos right back,
sensor was put in both tail pipes both read identical so this ruled out the first 3 and last 3 cylin runnin differnt
also the exhaust has 02 ports just after dumps, put in both sides up front and same thing reads perfect A/F ratios
Sounds like super polished combustion chamber - did you specify a combustion chamber suface finish? However if the pulgs are black then I would be looking at the tune. Any chance its really rich on cruise and idle?
only when it get into load the dyno room starts filling up with smoke and fumes
on idle and cruze its fine.
the reason for the retune in the first place is i had some crap go threw my turbos, had the turbo wheels replaced and fitted them backup.
changed the catch can setup from intake sucktion to just atmo filter. also put the blitz bovs on and hks twin power.
when its a full noise and bellowing out black smoke the afr are reading a perfect 12.0 that why its got us stumped. we even wiped the tune and started again but same thing.
super polished combustion chamber why would this cause bellows of black smoke? the head was ported and polished and also the combustion chambers where polished but cant see that being the reson for the smoke.
and i dont mean a little puff of black smoke, it filles the whole dyno room in a power run its that bad. but power is there 375awkw on pump fuel straight up
Polished combustion chambers cause less atomisation hence the 12:1 AFR and exess soot. Seen it on many cars with polished combustion chambers. The sards wont give you great atomisation either.
12.0 isnt perfect. different for every car. under full load 13 idle 14.7 is a good start.
What else causes black smoke? Everyone tells me my Stagea blows black smoke, but I've had it dyno tuned so it goes ramps up to 11.4:1 up in the revs. Would that be too rich? I have a 100cfm 5" cat, would that have anything to do with it? Sorry for hijacking.
when your turbo's crapped themselves did oil go through ur intercooler? you may have residue oil in there that get pushed up under boost... another thing to check is decel fueling coz if its real rich it takes some time to burn all the excess away. What ECU are you using?
Turbos didnt fully crap themselfs, i was doing some maintance checks and fould my comp wheels abit chewed up, so just had new front wheel put on.
if it was burning oil it wouldnt be black smoke would be blue. also you can smell that it def fuel.
its running a pfc pro
reguards to plugs running .7 gap and not sure what heat range, same as what we have always run tuner has them in bulk lol
when you baby it around then only give it stick now and again it blows out all the deposits (condensation and carbon type build up).
Hmmm that could be it. Gets babied most the time and give it the stick every now then..
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
