Travis Trayhern Posted September 23, 2010 Share Posted September 23, 2010 first a quick run down of whats going on any help would be great as we have exhasted all options. its on the dyno getting a tune the A/F perfect 12.0 threw the rev range but just excess fuel black smoke coming out of the exhaust. now we have changed O2 sensors on the dyno A/F reader also borrowed another one from another tuning shop down the road, both read fine and identical when charts compaired. pulled my car off and put a differnt car on the double check and the sensor is reading perfect. now there is no power loss and response is great but just excessive black smoke and fumes/fuel you can smell it. put a brand new O2 sensor in can come out black as f*** also changed plugs after and where realy carboned up. run down on engine fully forged head work cams tomie b -5 turbos pfc pro z32 afm's full race twin kotomoto exhaust dumps hard piping kit intake and cooler blitz bovs hks twin power cdi yellow jakets coils 800cc sard tomie reg 044 surge tank hks cam gears any ideas would be great cheers Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/ Share on other sites More sharing options...
sky30 Posted September 23, 2010 Share Posted September 23, 2010 what exhaust you got, and where was the sensor placed on the dyno? Did you try putting the sensor in different spot? If you have external gate, screamer pipe works well. Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5462722 Share on other sites More sharing options...
Travis Trayhern Posted September 23, 2010 Author Share Posted September 23, 2010 its twin seperated from the turos right back, sensor was put in both tail pipes both read identical so this ruled out the first 3 and last 3 cylin runnin differnt also the exhaust has 02 ports just after dumps, put in both sides up front and same thing reads perfect A/F ratios Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5462735 Share on other sites More sharing options...
rob82 Posted September 23, 2010 Share Posted September 23, 2010 its twin seperated from the turos right back,sensor was put in both tail pipes both read identical so this ruled out the first 3 and last 3 cylin runnin differnt also the exhaust has 02 ports just after dumps, put in both sides up front and same thing reads perfect A/F ratios Sounds like super polished combustion chamber - did you specify a combustion chamber suface finish? However if the pulgs are black then I would be looking at the tune. Any chance its really rich on cruise and idle? Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5462873 Share on other sites More sharing options...
Travis Trayhern Posted September 23, 2010 Author Share Posted September 23, 2010 only when it get into load the dyno room starts filling up with smoke and fumes on idle and cruze its fine. the reason for the retune in the first place is i had some crap go threw my turbos, had the turbo wheels replaced and fitted them backup. changed the catch can setup from intake sucktion to just atmo filter. also put the blitz bovs on and hks twin power. when its a full noise and bellowing out black smoke the afr are reading a perfect 12.0 that why its got us stumped. we even wiped the tune and started again but same thing. super polished combustion chamber why would this cause bellows of black smoke? the head was ported and polished and also the combustion chambers where polished but cant see that being the reson for the smoke. and i dont mean a little puff of black smoke, it filles the whole dyno room in a power run its that bad. but power is there 375awkw on pump fuel straight up Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5462925 Share on other sites More sharing options...
rob82 Posted September 23, 2010 Share Posted September 23, 2010 only when it get into load the dyno room starts filling up with smoke and fumes on idle and cruze its fine. the reason for the retune in the first place is i had some crap go threw my turbos, had the turbo wheels replaced and fitted them backup. changed the catch can setup from intake sucktion to just atmo filter. also put the blitz bovs on and hks twin power. when its a full noise and bellowing out black smoke the afr are reading a perfect 12.0 that why its got us stumped. we even wiped the tune and started again but same thing. super polished combustion chamber why would this cause bellows of black smoke? the head was ported and polished and also the combustion chambers where polished but cant see that being the reson for the smoke. and i dont mean a little puff of black smoke, it filles the whole dyno room in a power run its that bad. but power is there 375awkw on pump fuel straight up Polished combustion chambers cause less atomisation hence the 12:1 AFR and exess soot. Seen it on many cars with polished combustion chambers. The sards wont give you great atomisation either. Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5462978 Share on other sites More sharing options...
STATUS Posted September 23, 2010 Share Posted September 23, 2010 are the plugs consistent ie all black? Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5463060 Share on other sites More sharing options...
Travis Trayhern Posted September 25, 2010 Author Share Posted September 25, 2010 are the plugs consistent ie all black? yes very black plugs all over carbon built up after a few runs on dyno with new plugs Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5465547 Share on other sites More sharing options...
GTR1993 Posted September 25, 2010 Share Posted September 25, 2010 accel enrichment? I have noticed even when I have been tuning my gtr it seems to pump the black smoke even when its not that rich. Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5465766 Share on other sites More sharing options...
brendo.r32 Posted September 25, 2010 Share Posted September 25, 2010 only when it get into load the dyno room starts filling up with smoke and fumes on idle and cruze its fine. the reason for the retune in the first place is i had some crap go threw my turbos, had the turbo wheels replaced and fitted them backup. changed the catch can setup from intake sucktion to just atmo filter. also put the blitz bovs on and hks twin power. when its a full noise and bellowing out black smoke the afr are reading a perfect 12.0 that why its got us stumped. we even wiped the tune and started again but same thing. super polished combustion chamber why would this cause bellows of black smoke? the head was ported and polished and also the combustion chambers where polished but cant see that being the reson for the smoke. and i dont mean a little puff of black smoke, it filles the whole dyno room in a power run its that bad. but power is there 375awkw on pump fuel straight up 12.0 isnt perfect. different for every car. under full load 13 idle 14.7 is a good start. Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5465793 Share on other sites More sharing options...
Adriano Posted September 25, 2010 Share Posted September 25, 2010 12.0 isnt perfect. different for every car. under full load 13 idle 14.7 is a good start. OMG Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5465857 Share on other sites More sharing options...
R31Nismoid Posted September 26, 2010 Share Posted September 26, 2010 lol... Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5466098 Share on other sites More sharing options...
DVS JEZ Posted September 26, 2010 Share Posted September 26, 2010 Weird one.. Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5466273 Share on other sites More sharing options...
-_-StRyDeR-_- Posted September 26, 2010 Share Posted September 26, 2010 12.0 isnt perfect. different for every car. under full load 13 idle 14.7 is a good start. Hmm....interesting... Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5466299 Share on other sites More sharing options...
rob82 Posted September 26, 2010 Share Posted September 26, 2010 yes very black plugs all over carbon built up after a few runs on dyno with new plugs What heat range plug and what gap? Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5466371 Share on other sites More sharing options...
BoostedBarge Posted September 26, 2010 Share Posted September 26, 2010 What else causes black smoke? Everyone tells me my Stagea blows black smoke, but I've had it dyno tuned so it goes ramps up to 11.4:1 up in the revs. Would that be too rich? I have a 100cfm 5" cat, would that have anything to do with it? Sorry for hijacking. Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5466384 Share on other sites More sharing options...
NoFigJamHere Posted September 26, 2010 Share Posted September 26, 2010 when your turbo's crapped themselves did oil go through ur intercooler? you may have residue oil in there that get pushed up under boost... another thing to check is decel fueling coz if its real rich it takes some time to burn all the excess away. What ECU are you using? Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5466584 Share on other sites More sharing options...
Travis Trayhern Posted September 26, 2010 Author Share Posted September 26, 2010 when your turbo's crapped themselves did oil go through ur intercooler? you may have residue oil in there that get pushed up under boost... another thing to check is decel fueling coz if its real rich it takes some time to burn all the excess away. What ECU are you using? Turbos didnt fully crap themselfs, i was doing some maintance checks and fould my comp wheels abit chewed up, so just had new front wheel put on. if it was burning oil it wouldnt be black smoke would be blue. also you can smell that it def fuel. its running a pfc pro reguards to plugs running .7 gap and not sure what heat range, same as what we have always run tuner has them in bulk lol Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5466595 Share on other sites More sharing options...
STATUS Posted September 26, 2010 Share Posted September 26, 2010 What else causes black smoke? Everyone tells me my Stagea blows black smoke, but I've had it dyno tuned so it goes ramps up to 11.4:1 up in the revs. Would that be too rich? I have a 100cfm 5" cat, would that have anything to do with it? Sorry for hijacking. when you baby it around then only give it stick now and again it blows out all the deposits (condensation and carbon type build up). Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5466648 Share on other sites More sharing options...
BoostedBarge Posted September 26, 2010 Share Posted September 26, 2010 when you baby it around then only give it stick now and again it blows out all the deposits (condensation and carbon type build up). Hmmm that could be it. Gets babied most the time and give it the stick every now then.. Link to comment https://www.sau.com.au/forums/topic/337935-400kw-gtr-fueltune-issue/#findComment-5467060 Share on other sites More sharing options...
