Carbon Fibre S2 Front Foglight/indicator Surrounds Group Buy!
Ah ok, was just thinking that because parts like CF bonnets weren't legal these might not be. But then these aren't exactly doing much in a crash :) all good!
As soon as 10 people are gathered PSI parts will start manufacturing them as that is the minimum required. So there kind of isn't a date as such....is that cool?
If not I can put a date up, but we only need two people anyway so it would be a safe bet it would be filled this week.
I understand there but there needs to be a 3 month cutoff date for even a EOI - otherwise a EOI could run for 6 months.
Ok no worries man.
Cut off date to get the 10 people needed will be until next Friday the 8th October. If another person aint found by then I will put my name down for two so we can get these manufactured :down:
Edited by PM-R33
Rigteo, need two more people then. Guys ask some of your friends or something, surely out of the millions of Skylines in Aus there are two more people that would want these. Don't make me have to buy three lol.
Edited by PM-R33
ill chip in for the other one, we'll just leave em available for 2 others when they come along
Yeah righteo. I'll let send Shane a message saying we have 10 ready for purchase :)
BUY LIST
1. PMR33
2. EIRESGAUS
3. NA BEAST
4. DELLJIT
5. SSXRICHO
6. 75COUPE
7. AHH 33 S2
8. MSTRSHENANIGANS
9. PMR33 (Extra set)
10. NA BEAST (Extra set)
GROUP BUY IS A GO!
I have spoken to Shane from PSI parts and they are sending the covers to get the moulds created since we have 10 kits on order :rofl:
So here we go.
The carbon surrounds have been added onto PSI Parts' website as can be seen here:
http://www.psiparts.com.au/detail.htm?ProductID=R33S-FOGL-CF
You will notice that they are at a RRP of $199 + $20 freight = $219. However our price is $119 + $11 freight = $130. This means a saving for us of $89 due to the initial group buy.
To receive this saving, a coupon must be used: R33FOGSAU
Here is a link showing how to use the coupon:
http://www.psiparts.com.au/faq-coupon.htm
And here is a link showing how to shop on PSI Parts' website:
http://www.psiparts.com.au/faq-additem.htm
So if everbody could start paying for them ASAP, the sooner we can all get them :D
If you have any questions feel free to forward them to me or to Shane at PSI Parts.
(Remember, more people can still join the group buy, just put your name down)
Thanks guys :(
Phil
Edited by PM-R33
I went to order it but when i enter the coupon code it says "Coupon Expires"
I have fixed the error, please try again.
Thanks,
Shane
I'm going to assume the coupon will work until the first batch has been made (as in this initial group buy) and is ready to ship out. Similar thing to the carbon cooling panel. You interested in a set?
I will make payment from next weeks pay :P
Edited by PM-R33
So is there actually an expiry date for the coupon or is it there all the time?
The coupon is only valid for the first batch and I will make it expire on the 22/10/10, so that gives you until Friday fortnight to get your order in.
Thanks,
Shane
Yes please :(
So you willl take NA Beasts extra kit and the next person that joins in will take my extra kit.
BUY LIST
1. PMR33
2. EIRESGAUS
3. NA BEAST
4. DELLJIT - Paid
5. SSXRICHO
6. 75COUPE
7. AHH 33 S2 - Paid
8. MSTRSHENANIGANS
10. AAARGH 33
Edited by PM-R33
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
