Carbon Fibre S2 Front Foglight/indicator Surrounds Group Buy!
Hi Guys,
I just wanted to thank everyone for the patience and understanding in this group buy.
I am very proud to say THEY HAVE ARRIVED!! I am busy packing these up for you all I will have them in the post tomorrow with delivery before the weekend.
You will receive an email with your tracking details tomorrow.
Thank you again to all of you.
Cheers,
Shane
PSI Parts
  • Like 1
Ok, I have been to the post office and they were all sent Express Post so expect them tomorrow guys.
You all should have received an email with your tracking details also.
Shane
managed to snap off one of the screw points while fitting.. im raging so hard right now lol
hopefully an adhesive helps..
Oh man that sucks. I was so paranoid about doing the same thing. Try some hardcore superglue or just don't worry about the one.
My stock ones had two snapped off from a minor prang with a roo years ago and I didn't even know about it.
wow Phil i cant believe how dissapointed i am right now with the fitment of these, i go to put the right hand side 1 on first and 3 out of the 6 tabs are about 5mm out of where there supposed to be and are no where near fitable, all the tabs on the right surround are overly to fat compared to the left side surround where the tabs all look beatiful and alot neater. i know with being aftermarket and carbon there not going to be 100% but to completely not line up is not cool.
Been waiting so long for these and for them to not fit is so dissapointing, i dont want a refund would just like a set that fits!
  • Like 1
If you have a drama send us an email with a pic and an explanation with what the drama is and we can sort it out.
Hmmm that's strange man. Mine were nearly all spot on. A couple needed a slight "push" with the screwdriver to move them a millimetre or so, but nothing that would make it not fit :(
i glued the mount back on but ended up just ignoring it since it didnt really influence the fitment
regarding fit, i found it was out a bit too. 2 points on each cover require the mounting point to slot inside, and the points on this cover are just too fat to fit inside the little circle on the foglight assemply
i ended up just trimming about 5mm off the 2 points on each cover. just used a hacksaw blade took about 10mins
  • Like 1
I wonder why mine didn't have any problems? Like I said, a couple of the screw holes were slightly aligned wrong but only by maybe a mm. And some of the holes were drilled slightly to big so I just needed slightly thicker screws but that was it.
Delljit, looks good man. You happy with it?
well i had to use wider screws, and the 2 mounting points that are closest to the centre of the car were too long to fit into the assembly's standard points so i had to hack saw a few mm off to compensate
it looks good but was a bit more screwing around than i initially anticipated
happy with the end product in terms of appearance, not as happy in terms of needing adjustments
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
