BUILT RB26 for sale :D
RB26 forged done 10K since full rebuild - all parts done 10k with receipts. Gavin Wood Autotech built engine 476RWHP @ 19psi
CP pistons / rings
Balance & shot peened crank (long nose oil pump drive)
ACL bearings throughout
N1 water/Oil pumps
HKS step 1 cams 8.7lift 256in 264ex
Tomei cam gears
Tomei oil restrictor
Comes with 2860 - 7 turbo's fitted to engine
Long Motor only no accessories fitted
Selling due to upgrade $5900
PARTS FOR SALE :blink:
Power FC and hand controller suit R32 GTR $900
Boost control kit power FC $370
HKS 660cc injectors x 6 done 10k $700
Blitz intake pods with elbows and fittings complete suit R32 $280
HDI Boost controller brand new unused $350
Complete set 32 GTR brakes includes f/r calipers discs and pads $450
Aftermarket front pipes suit GTR $150
Transfer cases working perfectly $200 (2 available)
32 GTR indicators l/r $80 each
Allparts available Brisbane Northside. Can view engine in car - engine will not be removed until sold. Pictures up soon but we all know what these parts look like. Frieght at buyers expense- best contact PM -
Cheers
Jono
https://www.sau.com.au/forums/topic/337961-built-rb26-and-r32-gtr-parts-sale/
CP pistons / rings
N1 water/Oil pumps
Tomei cam gears
PARTS FOR SALE :P
Cheers
Jono
Does this include the turbos? Sounds like a bargain!
I wouldn't imagine this will last long!!!!
Has the car been down the 1/4 at all?
-7's are included with the long motor!
32 ran 11.1 @ 126mph @ Willobank raceway
Good price for this built Gavin Wood built 26
Hey mate, would u be keen to seperate the head and ill take the cams and cam gears off ya... u keep the turbos and manifolds?
PM me or call us if ur interested 0432528844
cheers Joe
Edited by GTR_JOEY
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
