BUILT RB26 for sale :D
RB26 forged done 10K since full rebuild - all parts done 10k with receipts. Gavin Wood Autotech built engine 476RWHP @ 19psi
CP pistons / rings
Balance & shot peened crank (long nose oil pump drive)
ACL bearings throughout
N1 water/Oil pumps
HKS step 1 cams 8.7lift 256in 264ex
Tomei cam gears
Tomei oil restrictor
Comes with 2860 - 7 turbo's fitted to engine
Long Motor only no accessories fitted
Selling due to upgrade $5900
PARTS FOR SALE :blink:
Power FC and hand controller suit R32 GTR $900
Boost control kit power FC $370
HKS 660cc injectors x 6 done 10k $700
Blitz intake pods with elbows and fittings complete suit R32 $280
HDI Boost controller brand new unused $350
Complete set 32 GTR brakes includes f/r calipers discs and pads $450
Aftermarket front pipes suit GTR $150
Transfer cases working perfectly $200 (2 available)
32 GTR indicators l/r $80 each
Allparts available Brisbane Northside. Can view engine in car - engine will not be removed until sold. Pictures up soon but we all know what these parts look like. Frieght at buyers expense- best contact PM -
Cheers
Jono
https://www.sau.com.au/forums/topic/337961-built-rb26-and-r32-gtr-parts-sale/
CP pistons / rings
N1 water/Oil pumps
Tomei cam gears
PARTS FOR SALE :P
Cheers
Jono
Does this include the turbos? Sounds like a bargain!
I wouldn't imagine this will last long!!!!
Has the car been down the 1/4 at all?
-7's are included with the long motor!
32 ran 11.1 @ 126mph @ Willobank raceway
Good price for this built Gavin Wood built 26
Hey mate, would u be keen to seperate the head and ill take the cams and cam gears off ya... u keep the turbos and manifolds?
PM me or call us if ur interested 0432528844
cheers Joe
Edited by GTR_JOEY
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
