hi guys,
me and my mate installed a lt10s into my rb20 over the weekend, started it up, and with the base tune it seems like its idling weird. kind of pops/knocks. . .
tps is showing 0% load.
also im not 100% sure that the knock sensor is hooked up correctly either. . . can anyone post up the wiring diagram for the tps sensor/switch?
i have read that on first start you have to adjust the tps? and lock in the timing??? any suggestions on how to go about??
Any help is appreciated! cheers
https://www.sau.com.au/forums/topic/337967-microtech-rb20det-install/
Use hand controller to lock timing - Do not rev the motor!
Use timing light to set engine to correct base timing by adjusting the CAS.
When timing is set correctly, unlock timing with the hand controller.
You have the Microtech manual right?
Also the Microtech doesn't use the knock sensors.
Edited by PM-R33
ok, so ive sorted out the tps. microtech is showing 0% then 99% with throttle.
im still not 100% about the CAS wiring. . .
Also, since ive relocated my battery to the boot. when i switch on my isolator switch, sometimes it seems like the coils spark and it even pops! any ideas on what i should check??
Cheers!
Also, since ive relocated my battery to the boot. when i switch on my isolator switch, sometimes it seems like the coils spark and it even pops! any ideas on what i should check??Cheers!
check yellow pages and find an auto elec in your area
but it really is, for the time it takes and people trying to diagnose it over the net without realtime testing and by the sounds of it there is some major issues with how ever it has been wired up.
all the diagrams needed are on the microtech website, we get guys ringing 10000 times a week with similar issues and it is always wiring related, so unfortunately we just refer them straight to a dealer of whichever product it is. I dont take on half wired jobs as it often takes longer to fix than a new install...
jump on the microtech website and check you cas wiring to their diagrams
http://www.microtechefi.com/pdf/LT12NISSAN6CYLign.pdf
hey trent, its got a base map on it, ive gone through the tps set-up and adjusted the timing to 10btdc, but its still running really rough. is that common?
Edited by I8EE
whats the idle af?
A microleb is a downgrade from the stock ECU, personally I'd sell it. They don't have closed loop O2 feedback so you are going to get rubbish economy unless someone spends hours and hours on the lower load cells when tuning it.
its a dedicated drift car, so i dont care for economy lol
pulled the plugs out trent and there soaked in fuel....thats base mapping for ya.... gonna chuck in the 750's i got and bring it in on the 9th
yeah its showing 14.7 on the h/c. tried trimming it down to 20% but its still rich. . . plugs are soaked in fuel. . .
ignore that, its about 1000000000000000000000 light years off being accurate. use a real lambda sensor or lean it off in steps until it stalls then about 2 page up steps will get it idling if the wiring etc is all correct
Agreed. Just keep trimming it down. Is the vacuum/ boost line connected?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
    • Wonder what the cause is, but here's hoping it's nothing too serious.
    • People don't always want builds that are overly expensive, or have engineering/registration/insurance issues and head aches that come with them Whilst big dollar builds, and complicated stuff is interesting to watch, there is only a tiny % of people who would actually use this information, or have the spare finances to drop on said builds, whereas the buy a cheap(ish) cool car, and make it better, with a average budget, that the average Joe or Jane could achieve will always be a winner in my opinion
    • Bit of a thread revival, you mentioned wanting a bit more top end before, do you regret not going with the 1.01?
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
