so i have an r33 rb25det thats in my car and an r34 rb25det that i want to buy. now question is can my intake manifold fit which i hear it cant and can it be modified to fit? i havent seen online to buy an r34 intake that doesnt have r32 and r33 all over it. ive did a little research and didnt come back with much. are would be easier to switch out the lifters into my r33 head, which the whole reason i want the r34 head.
https://www.sau.com.au/forums/topic/337999-r33-vs-r34/
Why do you want a R34 head? Its not specifically "that" much better.
Plenty here have made 350-370rwkw through a stock RB25 head (non NEO).
As for the plenum - by research - did you search here on SAU?
http://www.skylinesaustralia.com/forums/R3...p;hl=r34+plenum
There is plenty of this type of info here - they were the first two results as well
https://www.sau.com.au/forums/topic/337999-r33-vs-r34/#findComment-5463667
i wanted to use the solid lifters from the r34 head. im already at 600whp but flow will not be any better unless i use solid lifters to go above 8k rpm for my turbo size.
https://www.sau.com.au/forums/topic/337999-r33-vs-r34/#findComment-5464650
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
