so i have an r33 rb25det thats in my car and an r34 rb25det that i want to buy. now question is can my intake manifold fit which i hear it cant and can it be modified to fit? i havent seen online to buy an r34 intake that doesnt have r32 and r33 all over it. ive did a little research and didnt come back with much. are would be easier to switch out the lifters into my r33 head, which the whole reason i want the r34 head.
https://www.sau.com.au/forums/topic/337999-r33-vs-r34/
Why do you want a R34 head? Its not specifically "that" much better.
Plenty here have made 350-370rwkw through a stock RB25 head (non NEO).
As for the plenum - by research - did you search here on SAU?
http://www.skylinesaustralia.com/forums/R3...p;hl=r34+plenum
There is plenty of this type of info here - they were the first two results as well
https://www.sau.com.au/forums/topic/337999-r33-vs-r34/#findComment-5463667
i wanted to use the solid lifters from the r34 head. im already at 600whp but flow will not be any better unless i use solid lifters to go above 8k rpm for my turbo size.
https://www.sau.com.au/forums/topic/337999-r33-vs-r34/#findComment-5464650
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
