R33 Gts-t Having Rings/ Pistons Replaced. What Would You Do At Same Time?
A factory motor is more than fine - depending on the application.
Hence if you tell us how much you have to spend, what your intended use of the car is etc etc - people can help rather than just keep throwing ideas around that might not offer you any real benefit at all.
Stock heads are fine, stock bottom ends are also FINE if you only want say 250rwkw.
So why put forged pistons, rods, N1 pumps etc etc spending cash on the head and all sorts of stuff in there?
All you need is a new turbo, dump, injectors, AFM, ECU, clutch etc - That's 5k just there.
Dont forget suspension, most likely some attention to brakes and then suddenly its 7k-8k-9k
Ok, so i'm not going to be racing the car for the forseeable. It's got to be a reliable daily driver firstly, and up to 250rwkw would be more than adequate for my needs for a long time, I'll maybe have $2-3k extra to spend a year on it so I'm not chasing massive power.
So it does seem i'm best saving my money for now and just getting the car back in a running start first eh.
Looking at the brakes will be one of the first things I do though since they don't pull it up quite as well as I thought they should, then start having a good look at anything else that's not been kept on top of maintenance wise. I'm learning more about all the other mods I can do and mostly bolt on, so I'll start making a plan for those things after it's reliable first.
Is it a car yard? Im guessing they will give it a quick hone in the car, new rings and slap it back together. If the piston is damaged, they will only replace one with a factory item(they are $80) Thay really arent obliged to do any more if it is covered by warranty.
It's a yard but they have their own workshop and have been up front about everything so far, they could have just given it to me as is and told me that's how they run etc.
Maybe they will just do that so I guess it depends on what caused that in the first place eh? I'll be asking about the cause too, at this stage i'm more concerned about what else might be stuffed on there. Been trying to read about why they might fail eh, bad oil/ wrong oil/ not enough oil/ overheating/ dirt in the chamber etc.
If it's just one cylinder and they hone it and replace piston/ rings, is that alright?
I think i'll ask for the readings for all 6 cyls and see if they are just gonna do 1 or however many or them all so it's even.
Bollocks, now i'm worried it's been abused a lot and it might be one thing after another...
So is the "rebuilt" stock turbo now containing steel wheels?
No-one would rebuild it and put ceramic wheels back in there.
I would really hope not... I'll ask about that too. Is this obvious/ visible without taking the turbo off completely?
So it's cylinders 1 and 5 that have damaged rings and pistons. Mechanic reckons it's just been overheated at some point.
Would the cylinder numbers indicate a particular problem?
Getting the head checked and fixed next.
What can I do to prevent similar in future... I'm obviously going to take better care than the last guy but given that I live in sunny central Queensland should I be looking at anything to improve the cooling system?
Would it be related to the fact that there could be something wrong with the engine coolling?
Could running an FMIC or R34 GTT SMIC help precent this in future if say I wanted to drive it in a spirited manner occasionally? :-)
a good fuel system is a step in the right direction, as for cooling i never used to get more than couple degrees warmer when giving it some even around the track except when it dropped its coolant out the tell-tale hole when it was parked once. but up to you if you want more piece of mind. if it was 1and6 or 3and4 maybe 1and5 prob nothing in it.
Have you already bought this car? If you've only put a deposit down I would walk away at this point.
Thanks. I'm still puzzled as to how the dude managed to do it if it's not obviously crap getting into the cyinders. Been discussing with someone else and the possibility of it being overboosted at some point is also a consideration.
This has gone through my mind but I'm also thinking if they've had this good a look at the motor then I'll probably have the best history of the car I could hope for and I get something with a rebuilt engine that will last me a good while.
can you tell us the name of the car yard? Pm if you like. If its who I think it is I have a tale to tell you that should have you walking away quick smart!
Lol - you think a car yard trying to sell you an import is going to rebuild an engine that is going to ast you a while considering you're on a tight budget. Lol... Take the advice of people who have been there an done that - walk away from it! Seriously, you dont sound too mechanically inclined or knowledgable so I would walk or run as fast as you can...
Then again, buy it and we'll all have something to shake our heads at when you're back asking similar questions when it let goes in a couple of months time.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
