S13 in need of new home.
CA18det 5speed
unregistered but wouldnt need much to get back on the road.
showing 190k on clock
was defected 4 the usual fmic, pod, and oil leaks due to blowby. old owner never bothered to get back on the road so cashed the reg in
car goes really good, would make a cool daily or a mean little drift weapon
Engine:
recent strong second hand engine fitted, had a complete gasket reseal before engine went in have all reciepts.
Remaped ecu, socket fitted so can have memcal re written by any tunner who has the software eg. Dr. Drift
Most coolant hoses replaced
R33 radiator
Gtr injectors
FMIC with ally piping and turbosmart blowoff valve
T28 roller bearing turbo on stainless low mount manifold with teflon braided lines
Adjustable boost valve set at 10psi
3" dump into 3" "hiflow" cat into 2 1/2" with resinator and muffler
SR20 maf with hks mushroom pod
Monza catch can and fuel pressure reg
Exceedy clutch fitted no less than 5k ago
Walbro intank pump
Suspenion, brakes, body and wheels
full set of cs? zero 1 coilovers with front pillow joints.
height adjustable only i think, stiff ride by not harsh
recent disc's and pads, sloted rears and standard disc's up front
front strut brace
no rust in body or rear screen
Recent respray black with a light gold pearl.
has different colour bonnet bue battery arcing out and melting all paint, not that noticable.
spolier removed and holes filled but bog is starting to crack
nismo style grill
Koya 17" wheels multistud pattern with rwc tyres
very clean interior only damage to drivers seat
speco boost guage
impul gear knob
imobiliser
aircon removed, but all bits and pieces kept to be refitted
looking for offers aroung 7.5k
will post pics of interior when i get a chance
if sells for around that price will throw in all the rwc items eg standard cooler and supension etc
any interest post a pm or txt 0408536600
https://www.sau.com.au/forums/topic/338040-s13-very-neat-nice-mods/
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
