sorry for the topic
but
i have an application with dotars at the moment and the last contact i got from them was in the end of august and iv had nothing from them since.
is something going on there or are other people having the same problems??
i have emailed them this week but still no contact from them.
itll be a month since i got their last contact on monday.
im pretty over waiting at the moment :D
https://www.sau.com.au/forums/topic/338050-dotars/
sorry for the topic
but
im pretty over waiting at the moment :P
What is the application for, Personal Import or Race Rally.
https://www.sau.com.au/forums/topic/338050-dotars/#findComment-5464661
personal import. the last they said was if you provide us xxx document we will issue it.
but still nothing from them yet
Personal Imports, Pre 1989 and Race Rally are lower priority and they are looked at a lot closer, when someone submits a statutory deceleration stating it is a steel bodied 1937 rod and when inspected on the docks they find out it is a fairly new fibre glass bodied rod well they are vetting everything a lot more.
https://www.sau.com.au/forums/topic/338050-dotars/#findComment-5468067
obviously that happened recently?
personal import might be a lower priority but its been over a month since the last time they emailed me. its just a joke now.
surely theyd contact me to tell me whats going on????? i did everything they wanted me to do.
https://www.sau.com.au/forums/topic/338050-dotars/#findComment-5468193
I was told about it earlier this month so I would think it happened last month, it shows how game some people are and how the minority stuff it up for the majority.
If you emailed them a week ago I would email them again and only then call if no reply, I have had issues lately with there email system and a call was required.
https://www.sau.com.au/forums/topic/338050-dotars/#findComment-5468712
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
