Does a face lifted Series 1 count? ;)
Feeling alone? :D Welcome to my world 3 years ago lol
Don't think you will get the answer you are after mate, but at least there is a heap of info floating around for your engine and I am sure that there are a few of us here that are familiar with the VQ35de and the AWD drivetrain which is the same as the series 1
A HKS turbocharger or supercharger kit and the supporting mods is the answer to all your problems, Alex!
World Peace- nah, just twin turbos! And shhhh.... Don't tell anybody but I think "supercharger" is a dirty word around here :down:
I'm picking up really mixed messages about intakes from different places (whats new eh?) Agreed a Plenum spacer is a worthwhile addition, but I really want some good advice on the benefit of a CAI, pod or other set up before I jump in there. Options are:
1) get a high quality Panel filter in the stock airbox, and change the tube to a Z-Tube
2) get a kit that retains an airbox, but puts a pod in place, + a z tube or
3) a Nismo R tune kit
What are the recommendations, sometimes there is just TOO MANY choices!!!
World Peace- nah, just twin turbos! And shhhh.... Don't tell anybody but I think "supercharger" is a dirty word around here :)
If you are sticking with N/A.... go #3. It really is an awesome bit of kit :yes:
Or, you can buy the spare manifold off me, buy Andy's spare turbo and highflow it, fit an Emanage and youre away. :woot:
So you will make an intake pipe to go with it? Might need an intercooler with piping, BOV and stronger valve springs too
Or, you can buy the spare manifold off me, buy Andy's spare turbo and highflow it, fit an Emanage and youre away. :D
Scotty, I'm beginning to think you just want some competition on the VQ35 front! Sorry, but its going to stay NA for now. Might even get the most powerful NA Stagea in Aust! :happy: (and the only one who has bothered tuning it! :P )
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
